Parallel battery question
Discussion in 'Gen 2 Prius Technical Discussion' started by Jaron Lindow, Jul 4, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    One of the big differences I have noticed going from Gen 2 to Gen 4 is the lion battery seems to charge a whole lot faster.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I was thinking that the engineers probably did a lot of research to arrive at the most efficient size for the traction battery.
    It occurs to me now that a bigger battery would be bad for mileage for the same reason as forcing the present battery into EV mode and then making the car charge the battery from a lower SOC.
    Raytheeagle likes this.
    52,858
    how different would baseball be if the pitchers mound wasn't 60'-6" from home plate?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I’m just happy they have instant replay for certain plays;).
    Don’t get the purists all worked up .
  5. terramir
    terramir Member
    319
    51
    Los Angeles
    Ok three answers
    #1yes that would work but you would need to cool the second pack just like the 1st. If the individual modules are paralelled and only the bottom pack is wired to the car no additional bms will be needed but you will have to cross match capacities before hand or eventually it will go all out of wack. i.e the stongest of one pack with the weakest of the other etc.
    #2 the mpg should probably boost back towards the level of a healthy pack i.e. about 50 mpg paralelling a whole pack doesnt wirk because the bms cannot puck up the second pack properly but paralleling modules should. However unless the packs are really good the additional weight should offset any minimal gain in mpg from increased capacity after about 48-50 mpg.
    #3 Reality is getting the original mpg - wearlosses and the losses due to additional weight is realistic but getting more than what the prius was designed for out of the hybrid system is unlikely because that is the way it was designed. NiMH batteries have an almost 100% efficiency to 70% soc. Of course with our currents it's a bit less so yes reduced resistance and a bit more capacity can help in some cases like freeway driving to save a bit more recovered energy a bit more efficently but overall the 04-09 prius hybrid system is pretty maxed out.
    So yes doable yes but you'll have to use some plastic to direct the airflow. And well it might be a good idea for someone that is starting towards failure mode i.e. less than 30 mpg city but still gets good fwy milage.
    My $.02
    terramir
    Jaron Lindow likes this.
  6. terramir
    terramir Member
    319
    51
    Los Angeles
    Ehhh corrections since I can no longer edit cause the op liked my post
    #2 third line wirk=work 4th line puck=pick
    And #4 here is one thing you might want to note the ICE is used based on what current the hybrid system thinks it can draw and this is based on soc and current capacity of the pack so if the prius thinks you have a pack with a 6.5 + Ah capacity it thinks it can draw more than if you just parallel the pack and it only detects the one batteries capacity, so yes paralleling the modules would be far superior to paralleling the packs because the current detector is around the negative wire so yeah besides the wiring nightmare it would be far superior mind you you'll need 56 copper strips a little thicker than the busbars that are at least 6 inches long that you'll have to dump in plasti-dip for safety but yeah no reason it not just wouldn't work but it would also be far superior to parallel packs.
    #5 the voltage of the parallel modules would be held at the same voltage no worries there.
    Again my $.02
    terramir
    #26 terramir, Jul 5, 2018
  7. fuzzy1
    10,710
    You can't edit after 12 hours. Likes don't prevent editing.
  8. terramir
    terramir Member
    319
    51
    Los Angeles
    Ok, learn something new today :- )
  9. Jaron Lindow
    Jaron Lindow Junior Member
    24
    St George, UT, USA
    My first idea was bolting the additional batteries directly above the originals, but that's less safe and more work. It might be okay for a few modules as a proof of concept, but an operational setup would be easier and safer with an entire second battery pack, and then just re-configuring per the diagram. I'd also need to get an extra 26 bus bars since most of the connections would now be spanning 4 terminals instead of 2.
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    Doubling the battery like that would double the charging current frying the HV inverter or MG1. Not a good idea IMHO.
  11. terramir
    terramir Member
    319
    51
    Los Angeles
    Ehhh no the prius would not change the current with which it will charge the HV battery nor will the generator produce more current to charge the battery, in force charge mode may take longer than the original (new) battery to charge, but only if the combined capacity exceeds a new hv battery. Rechargable batteries don't suck energy out of the generator. The internal resistance of two new batteries in parallel, might be worrisome, if there was no regulation maybe, but not with an inverter and a computer inbetween. And this guy was planning to use two aging batteries to appoximate the performance of a new one.
    My $.02
    terramir
  12. Jaron Lindow
    24
    St George, UT, USA
    TechStream is showing 0.03 ohms resistance for the older blocks in the current battery. Twinning with similar modules would put that at 0.015 ohms per block. What internal resistance do factory new batteries show?
  13. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    No. 0.019 Ohms.
    0.030 Ohms is high.
  14. Jaron Lindow
    24
    St George, UT, USA
    Initial testing was done with 2 good modules removed from the battery and replaced with 2 weak modules which had previously caused the red triangle of death, twinned with two more weak modules which had also caused the red triangle.
    Initial charging caused the red triangle with the replace-battery code and code 3000 (if I remember right), which I cleared. The triangle did not come back with a small amount of additional testing, but results were inconclusive due to high temperatures (108F outside, battery temperatures without the cover approaching 150F).
    It looks like disconnecting the battery causes the car to revert to an assumed 0.019 ohms resistance, and without the cover on I wasn't able to do enough testing for the system to come up with actual values.
    I've since added some ports with rubber grommets that will allow me to put the cover back on, and the weather this week should be 15F cooler, so that should help eliminate being overly hot as a variable.
    I need to put together a better clamp for the external modules to allow cooling and to secure them.
    I should have more useful test results later this week.
    fotomoto likes this.
  15. Jaron Lindow
    24
    St George, UT, USA
    For this testing, the battery cover was in place. The batteries started at the ambient air temperature of about 96F. The air conditioner was on the coldest setting for the duration of the test. There were some trouble codes initially after installing the battery, which I cleared.
    I stopped a couple of times during the test and measured the external batteries at 80F using an infrared thermometer, about 5 degrees warmer than the battery cover they were sitting on.
    The twinned batteries seemed to charge more slowly, which was to be expected. It may be me misinterpreting the data since it was hard to keep an eye on the voltages in Techstream while driving, but the twinned batteries seemed to discharge more quickly than the rest of the battery, which I was not expecting.
    Overall performance was poorer than with all good modules, and trip MPG was about 27.
    At the end of the test I ran a final system health check in TechStream, which showed the Replace Hybrid Battery code pending.
    The TechStream logs of the test are attached.
  16. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    Jaron, I admire your adventurous spirit but I was curious what results were you expecting? The factory BMS is sensitive to voltage difference between blocks and bases its SOC and next function on these levels. By using 4 modules instead of 2 and bad ones at that you've modified the discharge curve and introduced multiple cascading failures, so a failure within a single module will immediately create a drain on the "twinned" module. This creates strange activity on the monitored block.
    I've thought about adding two modules to the pack in series to build a 30 module pack. You just need to extend the battery cage to add two modules, no need to extend the case or bottom chassis, let them hang off the side. You will need to scoot the sensing harness down, putting the unmonitored modules close to the battery computer and extend both the positive and negative leads. As long as these modules are newer than the rest of the pack and properly matched in charge level they don't need to be monitored. Depending on how Toyota programmed the Hybrid Computer it might result in increased power and mileage or could result in overvoltage codes (which could be tricked with resistors).
  17. Jaron Lindow
    24
    St George, UT, USA
    I was expecting the twinned unit to have less resistance and greater capacity. I don't know if less resistance was achieved from the car's viewpoint since TechStream showed the values stuck at the defaults of 0.019 ohms, and eyeballing the voltage drop in the twinned unit when the system was pulling from the battery suggests either I didn't achieve increased capacity, or the twinned modules just weren't getting adequately charged.
    #37 Jaron Lindow, Jul 11, 2018
  18. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    Yes. Create modules of 4 cells instead of the current modules of 2 cells.
