parallel parking a prius
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Nov 30, 2013.
  1. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    practice, practice, and more practice
  2. agreendc
    agreendc Junior Member
    Amherst, New York
    I parallel park less than 20 times a year I would say, but I did have a part time job doing local deliveries in a panel van, so I got really used to backing into tight places.
    In my relatively little experience I don't think it is any different than any other car. Nora wrote turn and look, but I always think the mirrors are the easiest way for me personally.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've always referred to it as "park by feel"... when you feel the bumpers hit... you stop... :p
    GrumpyCabbie likes this.
  4. ny_rob
    1,968
    813
    L.I.- NY
    You're assuming that the guy behind me is actually paying attention- not texting, talking on his cell, girl watching, eating, or otherwise being distracted. And, many here actually think they can make you go faster by tailgating so they drive incredibly close with no margin for error. Have you ever taken a look at the cars in NYC? Every single one without exception has battle scars because of the way they drive here....
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Yes indeedy. We don't just have oversized houses, we generally have generous parking spaces.
    I've always been bad at reverse park and fortunately on my 2nd test I just had to do reversing round a corner instead (in June 1996 in the UK it was one or the other, don't know about now.)
    I rarely have to parallel park into tiny spaces, and but when I do parallel park in the Prius, I use the following principles:
    - Skip the straight bit: I find the straight bit just causes me to hit the curb so it's lock right, lock left
    - Feel like I'm surely going to hit the curb: guarantees that I'll be within an couple of inches.
    Then when I have to leave, despite the obvious physics of it all, I'm often uncertain that I'll be able to pull out easily.
  6. Air_Boss
    Air_Boss Senior Member
    4,204
    1,186
    New Yawk
    Park by feel/ear/touch, whatevs... You're parking and swapping paint, NYC-style, which explains the rash of "Bumper Buddy" guards flapping in trail behind cars driven around town..
  7. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    These instructions are very different from anything I was taught. In particular, I was taught to bring the parking vehicle up even with the car in front. Any comments about these directions from any of you expert parallel parkers would be appreciated.
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    (might be because you drive on the wrong side of the road :) )
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Pull up even with the car you're about to park behind. Reverse with the wheel turned all the way to the right and proceed until you are at a 45 degree angle to the parking space. When the front of your car is even with the rear of the car you're parking behind, turn the wheel all the way to the left and park the car.
    Usually works with a couple of adjustments.
  10. Lutchenko
    Lutchenko Will Perrin
    307
    211
    Milton Keynes England
    To be fair I didn't really read through them lol.
    Personally I tend only to overlap the car in front by an amount that leaves me being able to swing into the gap as soon as I start to reverse. Now I know I said use the auto park and I often do but the main problem with auto park is that it is sooooo slow to initiate and most times I've tried it in a busy street I have someone glued to my bumper before I start to reverse. The same often applies when parking manually in very busy streets, so on occasion I have resorted to dropping the nose in first and then having to jiggle back and forth.
    I realise that you are probably going to tell me to indicate in plenty of time to let the people behind know that I have claimed the parking space and hence allow room for the manoeuvre. However in some cities such behaviour is a seen as a potential weakness leaving an opening for the car behind to jump, headfirst, into the gap you tried to claim :cry:
    Remember a shop window is your best friend when parallel parking :)
  11. Lutchenko
    307
    211
    Really? lol :)
  12. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The picture is exaggerated. The vehicle would not be positioned like that as it wouldn't normally be able to turn that sharply while moving slowly in reverse.
    Try the suggestion and you may find that it works. And maybe not. I've only been driving for about 50 years so I may not have the technique down.
  13. Lutchenko
    307
    211
    It was a joke really but I suspect that you're not parking in exactly the way you describe as if you reverse in at 45 degrees until the point you suggest it doesn't work. If however you use 25 degrees instead it looks like it should.
    Here is a method however that does use 45 degrees.
    Pull up three feet away from the car you want to park behind. Make sure to align your back tyres with the other car’s back bumper.
    Start reversing and turn your wheels all the way to the left.
    Very slowly back up until you are at a 45-degree angle, then stop.
    Turn the wheels all the way to the right.
    Back up very slowly until you are parallel with the curb.
    If done correctly, you should be less then twelve inches from the curb.
  14. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Anyone know if the Bumper Buddy fits/works on the Prius?
  15. Air_Boss
    4,204
    1,186
    New Yawk
    The ones that hang out of the trunk lid? I see them all the time on Prii.
  16. mediahound
    903
    155
    Yeah, like one of these, I heard they don't fit on all cars and I've never seen one on a Prius.
    Thinking about getting one...
    Robert Holt likes this.
  17. Air_Boss
    4,204
    1,186
    New Yawk
    They may not sit flush, due to the width of bumper protrusion, but they are adjustable within limits and would certainly do the job, even if they look, well, unattractive.
  18. mediahound
    903
    155
    Thanks, the only thing that concerns me about it is that people might think it's okay to ram the bumper if they see one of those on my car.
  19. Air_Boss
    4,204
    1,186
    New Yawk
    That's my take -- they are a target of convenience. Don't be that guy.
  20. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    My god I thought you folks were making that up! Son of a gun. Is it a heavy foam?
    Are there armour-plated versions to protect against tailgaters who start shooting?
    Grumpy Cabbie: Unlike the UK and certainly unlike Germany, here in Virginia we do not require official driver training of any kind now. Parents simply have to sign off a form stating they have given their offspring X hours if driving instruction. So lack of skills like parallel parking and bad habits like tailgating are being passed down in undiluted form to the next generation of drivers.
    jdk2 likes this.
