Park Assist
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, May 22, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Just tried robopark -- back-in, specifically. Yay, I didn't crash into anything!
    iPhone ? Pro
  2. Mark McIntyre
    Mark McIntyre Member
    36
    51
    Boulder CO
    I have used the robopark for parallel parking on a couple of occasions. It works great but don't forget to use your brake. The first time I did it I took my foot off the brake and the reversing was very fast!
    My problem is that the car seems VERY picky with the back in mode. I have yet to have it tell me anything other than not available try again. I think it is looking for a very defined space between two other cars. Is that everyone else's experience?
  3. mr88cet
    2,313
    1,335
    Austin, TX
    I found it to be fairly choosy about parking places to accept the challenge on, but extremely so. As I recall, once I was pretty sure I was doing it correctly, it rejected 2 spaces and then took the third.
    iPhone ? Pro
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Backing into a parking place is so trivially easy that I've never tried the assist despite backing in every day at work.
  5. mr88cet
    2,313
    1,335
    Austin, TX
    I'm surprised that they have assistance for leaving a parallel-parking space.
    iPhone ? Pro
  6. MNdriver
    MNdriver Senior Member
    549
    577
    There's such a thing? I didn't know.
    My spot in my condo parking garage is right next to the wall - so I have to make a 90 degree turn along a concrete wall. I'd love to have assistance to gauge how clise my front bumper is to scrapping it.
  7. ruby
    ruby Member
    130
    78
    Pull up perpendicular to the spot so you are looking down the center of the spot you want to park in, no more than 3-4 feet away from the cars, and turn on the turn signal in the direction of the spot before engaging the button. Works much better for me when I use the blinker.
    I'm pretty sure the automatic parking won't work if one side is against a wall, according to the Toyota manual and instructional videos. You could try it but I don't think it will work. Regardless, the car should beep at you if you get too close to the wall. Mine beeps when parking in the garage because I need to get very close to the wall in order for the other car to fit as well.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    And thus doesn't help me back into my garage either, to make charging more feasible.
    iPhone ? Pro
  9. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I seldom use it to park, but use it to get out of tight spot.
  10. DHM2017
    DHM2017 New Member
    Tennessee
    I tried the robo-back today in the parking garage. While it did get me between the lines, it was much closer on one side than the other. So I had to manually readjust it so I wouldn't hit the other car with my door.
    mr88cet likes this.
  11. Tideland Prius
    16,657
    There seems to be some issues with the IPA2 (S-IPA) - between curbing the rims in Parallel Parking Mode and one sided parking in Back-in Mode.
    I have IPA in my 2010 and it still works with or without the Pre-Support function (although I have to correct the Back-In Mode with two taps of the arrow on the sreen because my bumper was side-swiped so it's slightly out of alignment). With the 12 sensors supplementing the back up camera, should the car be better at parking than mine?
  12. mr88cet
    2,313
    1,335
    Austin, TX
    I too have noticed that on two of the four times I've used it.
    iPhone ? Pro
