Park gear
Discussion in 'Gen 2 Prius Main Forum' started by jeepien, Jan 21, 2005.
  1. myride
    myride Junior Member
    61
    Houston Tx.
    not a bad idea to get instant responces. ill use it in the future only for important questions. as for the P button it works and thats good enough for me! :)
  2. removeum
    removeum Member
    407
    El Paso, TX
    8) TonyPSchaefer,
    Very nice, however, I must thank Tempus for providing the needed information in which to answer [jeepien's] question....
    Ben
  3. pepa
    pepa New Member
    102
    Rockford, Illinois
    Ken, I love to read Japanese, except I don't understand what these beautifull symbols mean :)
    Seriously - do you know if the manual is available in english?
  4. Tideland Prius
    16,665
    :oops:
    hehe. That's cool though for personalised messages. Didn't Danny do that for a message a long while back?
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I think there is no English version of the CD-ROM manual from Japan.
    However, there is an online subscription site in the U.S.
    http://techinfo.toyota.com/
    Regards,
    Ken@Japan
  6. altaskier
    altaskier New Member
    157
    Long Island, New York
    That's right - it was meant to be secret information. But now that some info from the emergency response guide has been quoted on the site, the secret's out!
    Looking forward to skiing at Alta in February... :lol:
  7. snarfo
    snarfo New Member
    53
    Uh, I'm Snarfo and I don't ever recall posting anything in this thread nor would I be so arrogant as to say (or imply) I'm some kind of Prius diety--- I still have ~2 months to go before I even get mine.
    No need for hazing and insults when the victim is guiltless, eh?
  8. snarfo
    snarfo New Member
    53
    So basically TonyPSchaefer and his ill-considered rudeness can go get boned, as my idol from Futurama would say...
  9. Marg
    Marg New Member
    155
    Eastern Ontario, Canada
    Snarfo,
    Don't get mad at Tony.
    The confusion began with a little bit of code that Jeepien put in a different message on a different thread. When this code is used, I see the word "Marg" in the message, you see the word "snarfo", jayman seens the word "jayman" and so on....
    Tony quoted Jeepien's original post in this thread (possibly not intentionally) which caused the confusion to spread a little bit.
    Now, while you're seeing "snarfo" in Tony's message, I'm seeing "Marg".
    See what I mean?
  10. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Alright, I suppose I have to apologize here. I was reading and posting with a keyboard in one hand and a dirty martini in the other. Friends don't let friends post drunk.
    Anyway. If you click the (Post Reply) button under the thread, you go to the Reply page. On that page, you will see a series of buttons for formatting (B,I, and U) and insertion of pictures, URLs, and the such.
    In the bottom row, there's a button called (YOU) for the insertion of the reader's screen name. Anywhere I insert the (YOU) command, you read your screen name. And yes, a better use is bulk email personally addressed to each reader, as done by by Danny some time ago.
    EXAMPLE: go like you are going to create a post, use the (YOU) command, and hit [Preview] to see your own name in the previewed message.
    Of course I knew this all along and so did Jeepien. That's why I congratulated him on such an excellent use of the command. It became apparent to me when I realized that he named me specifically though others were answering as though they had been named. There's only one way to do that.
    Sorry if I offended anyone. What was interpreted as ill-considered rudeness was intended to be a humorous continuation of the use of the (YOU) command. But more than anyone else, it's you, [YOU], that I'm sorry I offended. Because you are my favorite. :lol:
  11. DaveG
    DaveG Member
    806
    Vancouver, BC
    Lol... I saw my name come up through clever use of the YOU command, and I did know the answer... So here it is:
    "The shift control actuator is mounted on the side of the hybrid transaxle. Upon receiving an actuation signal from the transmission control ECU, the motor in the actuator rotates to move the parking lock rod, which slides the parking lock pawl, thus causing the parking lock pawl to engage with the parking gear that is installed on the counter driven gear. As a result, the hybrid transaxle is locked or unlocked mechanically."
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    So an electric motor pushes an actuator rod and moves the pawl into the splines? I can't wait until my shop manual arrives, there is a LOT to learn about this car.
    A similar electric motor arrangement actuated the front axle disconnect on my 2000 GMC Sierra. Believe it or not, the front axle came factory filled with 80W-90, even for models sent to Canada and Alaska. 80W-90 turns solid at -12 F.
    When I took delivery of my GMC, after a 1,000km break-in, I drained the front axle and refilled with a synthetic 75W-90. The dealer claimed I was nuts, wasting money, etc etc.
    Then there were a rash of front axle failures. When the gear oil turned solid, the electric motor would burn out trying to move the actuator pawl in the front axle. The fork would usually force the collar just far enough on the splines to cause grinding, which would quickly destroy the axle.
    I received notification of the TSB warning all dealers to immediately drain and refill every front axle on the lot, and to call their customers ASAP to do the same. Hehehe.
    The Toyota CVT appears to already use a synthetic transmission fluid, so I wouldn't worry about the parking pawl motor burning out unless you were in Siberia. But "torque lock" on a hill is another matter. Use the parking brake, it's a good habit to get into.
  13. snarfo
    snarfo New Member
    53
    As usual, cooler Canuck heads prevailed. Perhaps Marg should run for President down here...
    I had just woken up to pee in the wee hours and skimmed the posts and saw my name being dragged through the mud and grouchily-yet-eloquently did my thing.
    Thanks for the clarification!
  14. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    No problem, Tony. Can't break up a mutual admiration society over that.
    I don't know the nuances of the (ubb?) code, but anytime you use the Quick Quote button, the CODE of the post to which you are replying will appear.
    Guess I've just gotten enough bulk mail to be suspicious.
    jeepien (I'm a name dropper too!), you may wish to search for the threads along the line of "Do you bother to use the P button?"
  15. PriusTN
    PriusTN New Member
    I wish someone had actually contacted me about this question. I hadn't looked at the post until now.
  16. Tideland Prius
    16,665
    I guess DaveG gave us the answer we're looking for!
  17. PriusTN
    PriusTN New Member
    haha. its been a while since i've read the posts here. if i had known my name had been mentioned i would have answered the post. ah well....maybe next time someone will PM me.
  18. petteri
    petteri New Member
    203
    Plantation, FL USA
    Wow, thanks for the compliment! I just stumbled on this thread.. I'm really not an expert on the Prius at all! I didn't really know how it functioned but knew it was something along the lines explained here by those who really know the workings of the Prius.
    P.S. In case anyone's confused my avatar is the Toyota Formula 1 logo. I'm in no way connected to Toyota at all! Just a fan!
    EDIT: Oh, .... OK, neat trick!
  19. PriusTN
    PriusTN New Member
    LOL, awesome joke. I kept replying.I need this on my site. I was thinking wow....how did I end up in this coversation and its been a while since I posted.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Me too! Alta, Cottonwood, and Deer Valley have more than their fair share of snow, especially this year. But I'd never seen the kind of cold like here in Winnipeg.
    It's so cold, a certain body part will shiver so violently that it sounds like two coconuts rattling together.
