park lights will not go off
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, Sep 3, 2023.
  1. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    The $700 08 Prius that we just got in the last two weeks we got to rebuilt battery replaced in it yesterday The car drove great this morning it through the POAO I think it is code has two subcodes in the list I guess I've got to look them up and see what I need to do I cleared the code start the car and it runs and drives great I have no display at the moment but if I unplug the white plug forward of the steering wheel the top one the display will come on and it stays on for a while and till a few cycles and it goes back off but now the running lights front and rear the 194s will not turn off I have the car fully turned off the clock is not on etc get out of the car close the door the running lights are on all the way around I waited 10-15 minutes they're still on turning the switch seems to do nothing right now I've pulled the white plug out of the battery
  2. Tombukt2
    13,868
    2,520
    Durham NC
    I also have the code for the high voltage leaking over to the low voltage side of the car It comes and goes I reset it I can drive the car when I turn it off it may or may not come back on If it does I just clear it with TIS or tech and keep getting it I've had the HV battery replaced The old was original corroded bad nut connections all of it I also had the code the engine won't start keeps telling me it's out of gas in tech.. Even though it's full I know this because I dumped it out of a big large gas can.
