Park my Prius in a small garage
Discussion in 'Gen 2 Prius Main Forum' started by jbean, Mar 20, 2014.
  1. jbean
    jbean Junior Member
    78
    I have a 2009 Prius and I'm a veteran driver and parker. I just moved over the weekend and my new garage is much smaller than the previous one, but it is a two-car garage. I share it with someone who drives a Jeep. I can't see anything around me beyond the windshield wipers and I would love to hear how other drivers have handled parking in tight spaces, successfully. In the mean time I've been parking in my driveway for fear of denting/scratching my beautiful car. If you have some tips to share, I thank you in advance.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    amazon.com/PARKEZ-Flashing-Light-Parking-Garage/dp/B004Z87ZYW
    jbean likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I am one of those types who backs in and uses mirrors. If it will fit in there, you should be able to back in. Big plus if you have the back up camera on your Prius. In the old days, hung a key with a string from the ceiling. The key would hit the rear glass when it was time to stop. Of course you had to listen and it needed to be quiet. A tennis ball will also do the same thing.
    Pulling straight out seems easier to me than trying to pull in.
    Hope this helps.
    jbean likes this.
  4. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    i have 2 painted yellow lines on either side of the car space in the garage.
    same as the ones you see in large parking areas. that way i can see the lines when reversing into the garage, and i know im straight. i also have the factory reverse camera, so i can see the rear wall approaching and know when to stop.
    Jason.
    jbean likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    All those products and spatial aids can help.
    But exactly how tight is tight? If you can't see anything beyond your windshield wipers, that's going to make parking in the garage difficult regardless.
    I personally use those blind spot mirrors, on both mirrors with my Prius. But this is mostly to aid in passing and driving...not really to help in parking in super tight spots.
    Also even if you get the car parked in the garage, safely and where you want it, and then hang up or add some aides of your choice in outlining where you should return, some of it will rely on the person you are sharing the garage with, also being consistent in where they are parking their jeep.
    jbean likes this.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Tennis ball on a string.
    iPhone ?
  7. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    We use the tennis ball on the string for one of the cars. I also like placing a long 2x4 on the floor (or 4x4 blocks, etc) for the front tires to roll up to--that offers the best precision, as long as the lumber doesn't move.
    jbean likes this.
  8. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    If its so tight how do you get in and out.??
  9. Tideland Prius
    16,677
    It might be the length, not width that it's short.
  10. jbean
    jbean Junior Member
    78
    I like all the ideas. Thanks. The garage is not very wide. There's a pole on the left wall that gets in my way when I want to open my door. I'm going to try the piece of lumber. It shouldn't move if it's heavy enough.
  11. jbean
    jbean Junior Member
    78
    That is a huge problem. I can barely get in and get out.
  12. dorunron
    3,318
    1,105
    Houston, TX
    jbean,
    Structures do tend to get in the way at times. Without actually being on site, my suggestion would be to try to back in with the passenger side as close as possible without scraping anything. That should give you enough room that you can try to open the drivers door and then exit and enter that way. It is easier to back in as long as you use the camera. All Gen II models EXCEPT for base model came with the camera. Stopping point is the bottom view of the camera display. A wall, painted line etc. at very bottom of display will result in a inch of clearance normally. Check this with a trash can or painted stripe on parking lot to compare your camera display with actual reality before using it to back in. Use BOTH mirrors and camera when backing in and back in straight. When pulling out, pull out straight ahead. As long as you keep it to the right you might have enough room to do it that way providing the pole wont limit your ability to crack open the door enough to get in and out.
    The only other suggestion would be to switch places with the Jeep and see if that works better.
    Let us know how you finally get it worked out.
    I too am fixing to tackle the garage since I want to keep the new one inside at night.
    Best of luck to you.
    Ron (dorunron)
  13. ursle
    ursle Gas miser
    1,049
    192
    NH
    One of you has to back in and both park far against the wall, then you can both get in and out of your vehicles at least, good lighting and some practice and it will be natural. (the one with the backup camera should backup)
  14. jbean
    jbean Junior Member
    78
    Great suggestions. I'm not very comfortable backing into a tight space. I had the same idea of switching places with the Jeep. I'll see if we can experiment with it. Thanks.
  15. jbean
    jbean Junior Member
    78
    That makes sense. I don't know if the Jeep has a backup camera. I do. The lighting is terrible in the garage. There's only one light source coming from the overhead garage door thing.
