Parking a Prius over a month
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Jul 23, 2015.
  1. bisco
    52,863
    maybe grab a mini vci before living.
  2. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Ghana sells both leaded and unleaded gas. I don't know about Nigeria. I really didn't think those fuel additives worked. What additives would you recommend?
    MI 4LTE ?
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Ok so I just cleared my Prius from the port. I noticed that when it's parked and the ice kicks in to charge the battery, it ice shuts down right as the battery gets to 3 bars. Anybody knows why?
    XT1060 ?
    52,863
    yes, that's how it was designed. it won't charge to 5 or 6 bars until you do some regular driving.
    when you're parked, or stuck in stop and go traffic, it keeps the battery at 2-3 bars.
    glad you made it and your car started!(y)
    fopoku2k2 likes this.
  5. Mendel Leisk
    42,355
    No idea about your current problem, but regarding the gas: would leaded gas screw up the catalytic converter? Stay clear of it?
  6. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Yeah it started after jump starting it and leaving it on for an hour or so. I noticed that the car drives very low. I am thinking its due to the batteries under the seat. I would take physical measurements in the morning. But is this normal??
    App Runtime for Chrome ?
  7. bisco
    52,863
    if you drove the car normally for an hour, and it didn't come up to 5-6 bars, you may have a problem.
  8. Mendel Leisk
    42,355
    If the car needed a jump start, the 12 volt battery needs a proper charging session. Just running the car won't restore it. A smart charger, that monitors the battery as it charges, with a status display, is what you need. It's amperage should be near but not over 4.2.
    Considering the long inactive stretch I'd say the 12 volt is the prime suspect. Resolve that first and see how it goes.
  9. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Apparently the required octane level for a Prius is 87. I would check the local levels today
    XT1060 ?
  10. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I think it did come up to about 4/5 bars at a point.
    XT1060 ?
    #30 fopoku2k2, Sep 18, 2015
  11. bisco
    52,863
    that's probably about right. how many miles on her?
  12. Mendel Leisk
    42,355
    Octane ratings vary in different countries. In Canada the numbers are some different system, all you need to know is cheapest is fine. But where you are, maybe start with a mid-grade, see how it goes.
  13. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    About 235,000 miles
    XT1060 ?
  14. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    The octane levels here ranges from 89 to 95. I guess I should be find?
    XT1060 ?
  15. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I noticed my engine coolant is very low. Unfortunately I can't get the Toyota Genuine Fluid 00272-SLLC2 Long Life Coolant here in Ghana. Is there an alternative I can use?
    XT1060 ?
  16. Mendel Leisk
    42,355
    Yeah, just for caution try one grade up at first, then top up with the lowest when you've not used too much of that first tank. That way you introduce the lowest grade gradually. See how it goes.
    And I'm not that sure, but think you should definitely avoid leaded gas, for the catalytic converter.
    CR94 likes this.
  17. Patrick Wong
    18,210
    6,526
    Do not use leaded fuel under any circumstances.
    One alternative would be Toyota Long Life Coolant (vs. Super Long Life Coolant). This has a shorter service life, 30K miles instead of 50K miles.
    What do the local Toyota dealers sell? Use that.
  18. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    They only sell "ABRO" red and green Coolant. Since it didn't snow here they don't sell any antifreeze coolants
    XT1060 ?
  19. Patrick Wong
    18,210
    6,526
    I understand that it doesn't snow. The purpose of the antifreeze is to retard corrosion as well as to bring the freezing point of the coolant down.
    You should check with your retail auto parts suppliers to see what is available, and study the chemical composition of the coolant. I would not encourage use of coolant other than Toyota Super Long Life Coolant.
    Also check other African countries, perhaps South Africa? Can you buy the correct coolant there and have it shipped to you?
    #39 Patrick Wong, Sep 19, 2015
  20. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I just sent the local dealer in SA an email. But if the antifteeze is for cold snow regions, then why would it be necessary to use it in Ghana where there is no snow?
    XT1060 ?
