Parking a Prius over a month
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Jul 23, 2015.
  1. Patrick Wong
    18,210
    6,517
    The engine coolant and inverter coolant must serve three purposes:
    1. protect the aluminum components from corrosion
    2. lower the freezing point of the coolant
    3. transport heat to the radiator where the heat can be dissipated
    I recognize that in a tropical area, #2 is irrelevant. In my youth I lived in Honolulu, Hawaii which also is a tropical area. Regardless, the correct antifreeze is used there because that is a widely available fluid which satisfies all three purposes.
    #1 is very important. I would not trust a generic antifreeze to provide the necessary protection. Toyota's repair manual is specific about the chemical properties required of the antifreeze.
    Do not be tempted to use water as a coolant. The mineral content of the water will form deposits, and that fluid will promote corrosion of the metal which comes into contact with the water.
  2. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    4. Raise the boiling point of the coolant.
    You really don't want bubbles forming at hot spots within the coolant passages.
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    anybody knows what powers the AC? I noticed that at a stop, the ac still works with both battery and engine off.
  4. FrankB
    FrankB Member
    117
    53
    The traction battery powers the AC.
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Ooh ok. WOW!! then if my assumptions are right the AC doesnt really drain the traction battery that much???
  6. FrankB
    FrankB Member
    117
    53
    It depends on the speed the AC is running. If it's running at maximum, you will notice it draining the traction battery. If it's at the lowest setting, probably not.
    fopoku2k2 likes this.
  7. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    The engine ultimately powers it, via the motor-generators and inverter. On its way from the engine to the compressor, that energy sometimes makes intermediate stops as stored energy--in kinetic, potential, or chemical (battery) form.
  8. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Anybody knows what's that little black box underneath the passenger seat?
  9. bisco
    52,804
  10. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I don't think so. My Prius is a basic model. I only have radio and mp3
  11. Canard
    Canard Member
    223
    Ontario, Canada
    I had my Prius parked for about a month in my driveway this summer. When I started driving it again, the front brakes were making a lot of noise. The dealership said that the rotors had rusted beyond repair and I had to have both rotors and brakes replaced, for $1600.
  12. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Damn!!!! That's not good. Sorry
  13. bisco
    52,804
    unfortunately, the dealer took complete advantage of an uneducated consumer.:(
  14. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Hahahahahahaha. I can see that.
  15. Patrick Wong
    18,210
    6,517
    Next time, try bringing the car up to 50 mph or so, in an area where there is no traffic behind you. Shift to N and brake moderately to bring the car down to a very slow speed or a stop. Then shift back to D, bring the car back up to speed, shift to N, brake. Repeat several times and see whether you can sand off the rust via that method.
  16. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    How do you shift a prius to N?
    App Runtime for Chrome ?
  17. Patrick Wong
    18,210
    6,517
    The gear selector lever allows you to shift between D, N, R, and B.
  18. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Yeah. But you never answered my question.
    XT1060 ?
  19. Patrick Wong
    18,210
    6,517
    Apparently, I do not understand your question. Just move the gear selector to N.
  20. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Isn't it always in neutral?
    XT1060 ?
