Parking brake light stays on, NOT the switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cacao, Dec 28, 2020.
  1. ChapmanF
    19,047
    It's never a bad one.
  2. cacao
    cacao Junior Member
    38
    I've got it ordered, along with the required cable, I'll post my results once it arrives and I have it up and running.
  3. cacao
    cacao Junior Member
    38
    OK, I've made some progress. I did get Techstream, and got a C1344 code, as I understand it, a sort of generic brake system malfunction code. I then had the front rotors turned, and replaced the front brake pads. I then bled the brakes using Techstream, but noticed that the left rear cylinder did not bleed any fluid, unlike the right rear cylinder. After that, Techstream now shows C1344, Hydraulic System (RL), pointing out the cylinder that didn't bleed. So, what do I need to do from here?
  4. cacao
    cacao Junior Member
    38
    I'm getting different codes, so I am starting over with a new thread.
  5. Rich Nichols
    Rich Nichols Junior Member
    Manhattan Beach CA
    I have had the same problem and I thought I solved it once, but the parking brake light came back on again. Research tells me that the problem is likely that the switch has come loose from the mounting point and the switch ground is through that mounting point. Saw something somewhere about how to get to that mounting hardware, but can't find that now. Involves removing A/C vent to the left of the driver.....
