Parking brake question
Discussion in 'Gen 5 Prius Technical Discussion' started by HamiltonPrius, Nov 29, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    Well, with the Gen 4/Gen 5 Prius/Prius Prime HEV/PHEV, the problem is not the size of the size of the battery but the fact that the 12-V BMS does not fully charge the 12-V battery. It likes to keep it around a 75% SOC, but since it is buggy, this could drift down much lower.
    Regarding CCA, this was discussed before. The CCA on the OEM battery is reported according to the EN standard. The equivalent of an EN CCA of 285 A in the older CCA standard is about 470 A.
    2024 PP XSE 12v aux battery warranty replacement by toyota dealership | PriusChat
  2. broderp
    broderp Junior Member
    38
    OH
    2024 Prius
    Limited AWD-e
    This is my thought as well. I recall many times over the years that when spring came around, my mechanical EPB was frozen/seized. I don't care what the "Car Care Nut" says about electric parking brakes...it sounds like an expensive fil if it seizes and doesn't release. lol
  3. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    On the other hand, exercise may be good for it, lol.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,340
    963
    Monument, Colorado USA
    It works in our 2024 Corolla Hybrid. Start up the car, push down the parking brake button for about 3-seconds and the display will let you know it's been disabled. Hold it up for 3 and says it's activated. I love that thing but will, probably, have to use my scan tool when she needs a rear brake job BUT she's a Hybrid so probably won't need a brake job for at least 10-years....our 2017 Prius is, still, on the original pads and were at 6mm last time I checked.
    VelvetFoot likes this.
