Parking Brake vs Parking Button
Discussion in 'Gen 2 Prius Main Forum' started by Kablooie, Apr 20, 2004.
  1. Tideland Prius
    16,680
    But wouldn't the use of the parking brake result in the possibility of rear wheel lockup and a very slight chance the car will spin out (though I suspect VSC will try to prevent that). With a handbrake, at least you can have your thumb over the release button; it's harder on a foot brake.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    True. A hand brake is easier to control for emergency braking, but in the absence of any other means to slow down, a foot brake becomes an attractive alternative.
    Tom
  3. VoicesInMyHead
    VoicesInMyHead New Member
    52
    Georgia, US
    It's the parking pawl that is being relieved of force... and that, on most transmissions, is a tiny metal pin. I've had a transmission whose parking pawl has sheared because the car was parked only using the transmission on a hill. I started the car, moved it out of Park, and with a loud metallic *PING*, the pin sheared off. That was the last time the car parked anywhere without using the parking brake.
  4. Patrick Wong
    18,210
    6,517
    The parking brake is so weak that you don't have to worry about rear wheel lockup. Try it at highway speed when no one is behind you, and see how hard you have to press on the parking brake pedal to show a modest reduction in speed.
    Even if you apply the parking brake pedal with your full strength, you'll be waiting a long time until the car actually stops, and might feel like Fred Flintstone who had to stick his left foot out to help the stopping process. :cool:
  5. Tideland Prius
    16,680
    Cool thanks for the info!
    Well... I have slowed down the wheels enough to induce oversteer (not sure if they're actually locked) on snowy/icy roads.
  6. Patrick Wong
    18,210
    6,517
    Yes, I am not suggesting you try this on snowy/icy roads. Nor do I suggest that you turn the steering wheel hard, as you engage the parking brake at speed.
    Try it on a dry highway while steering straight ahead. Once you see how the car behaves under those conditions, then it is up to your view of safety vs. adventure if you want to try something more advanced.
  7. richard schumacher
    7,683
    1,066
    United States
    It's mostly a parking brake, not an emergency brake. Use it every time you park to keep the cable un-rusted and allow it to self-adjust so that it will be more likely to function if you ever do need it as an emergency brake.
  8. Tideland Prius
    16,680
    I know, I know.
  9. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Just call 911. :rolleyes:
    2 people like this.
  10. qbee42
    18,058
    3,081
    Northern Michigan
    This is true on many cars, but not for the Prius. The Prius parking pawl is a robust helical gear that screws into place. If you manage to break it, you have probably broken something else in the process.
    Tom
  11. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Makes me wonder, what's the first thread ever in this forum? Whoa, there are some dated from 1969 :)
    The first non-1969 post had to do with disabling the reverse beep (and seatbelt beep).
    On a more relevant note, it's good to know that my practice of Pressing the parking button before hitting the parking brake isn't really taxing my transmission!
