Parking light as DRL
Discussion in 'Gen 3 Prius Technical Discussion' started by Subayal, Sep 21, 2017.
  1. Subayal
    Subayal New Member
    Pakistan
    Sorry if it is a repeated question. Am new on Priuschat.
    how can I use parking light as DRL? I don't want to keep tail light on. Meaning, I want headlight parking light comes on whenever power is on (ready)
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Google search for webelectric DRL Prius. PriusChat member user offline has a guide on an install in his Prius v.
    Grit likes this.
  3. xliderider
    8,140
    3,280
    Honolulu, HI
  4. Subayal
    Subayal New Member
    Pakistan
    This is the headlight of my Prius. The Led strip below HI/LO beam projectors gets on whenever I switch to parking light. I just want to keep this LED strip on without turning parking light on. This way, it will work entirely as DRL whenever car is in ready mode
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I thought about doing that also. Splice the DRL power and ground, connect the parking bulb W5W t10 power and ground leads to DRL spliced leads. Then replace W5W t10 bulbs with LEDs. Anyone done that mod yet?
  6. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    not working/
    I tried it twice & every time it not only did not work, it also blew a fuse/
    ended up with the webelectric kit/
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks for the follow up update. I'm going to do something similar like that tomorrow morning but for footwell lights; add 12w cob led to each footwell connector and leave original footwell LED disconnected. Hopefully this doesn't blow the fuse as it is the same circuit w/all other interior lights which I swapped all to LED already.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    would it be okay to put in a higher current fuse, like going from 10 amp to 12amp fuse if you wired the parking lights with the drls safely?
  9. StarCaller
    1,284
    733
    might work, might not....
    exchanging fuses in a prius for stronger ones is kinda literally playing with fire/
    look at this thin thin 22 gauge wires & you know what I mean..../
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Very good point. By the way, the COBs worked fine without the fuse blowing with all the interior LEDs turned on including the led left of rear hatch.
