Parking lot with AC on, ICE comes expected.
Discussion in 'Prime Technical Discussion' started by Roy2001, Jun 27, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    While waiting in parking lot and outside temperature is about 90F, AC on, and ICE comes while battery has plenty of charge.
    Any idea why? Is this normal? I used to drive in EV mode and ICE won't be on, but I seldom idle for long period with AC on.
  2. Mark57
    2,945
    2,736
    OK
    It's 95° - 96° here with high dew point (68) to boot (high humidity) and I've not had this happen when in EV mode. I tend to keep my A/C in ECO and Auto with the temp set about 10° lower than the outside air.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Define. Also, what mode were you in at the time?
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It could also be a completely coincidental controlled burn that just happened to be when you were in the parking lot if the engine hadn't started in a while. Is EV driving the norm for you?
    FuelMiser likes this.
  5. Roy2001
    371
    158
    Sacramento, CA
    Thanks guys. I was using sport mode. I would try ECO.
  6. bisco
    49,490
    that won't affect it. i think he meant hv/ev/auto. are we sure the prime doesn't run the ice every so often? there sure are a lot of 'my engine started unexpectedly' reports.
  7. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    Do you mean Power Mode?
  8. Mark57
    2,945
    2,736
    OK
    Yesterday it was 100.4° with a dew point of 82. That's 55% humidity and sweltering if you've not felt it. I tried parking on black asphalt with the A/C on in full sun for 10 minutes, with 9 miles if EV range left. A/C was in Auto mode, ECO with the temp set at 80°. Car was in EV - ECO drive mode. The engine never started. My work is done here.;)
  9. bisco
    49,490
    yes, i think there has to be another factor involved.
  10. Mark57
    2,945
    2,736
    OK
    Yeah, but mine "knew" I was watching it. :p
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Good ol' observer effect in action.
    Mark57 likes this.
