Parking outside. Charging in the cold and rain?
Discussion in 'Prime Plug-in Charging' started by Darien Day, Dec 22, 2021.
  1. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    I don't have a garage to park in. My Prime parks under the open sky. Is it safe to charge it overnight when it's below freezing and when it's raining?
    Will the Prime use up more battery capacity while pre-heating or cooling than it can charge while I'm waiting for it to heat or cool?
    I know there are threads about this, but haven't seen a recent one.
  2. Tahsin Shamma
    Tahsin Shamma New Member
    16
    Massachusetts
    2022 Prius Prime
    Hi Darien
    As far as I have read on here and researched on other forums, unless it's pouring rain you're fine to plug it into the charger. If you're worried, they make products to cover the charging handle as it connects to the port.
    As far as I can see living in the northeast, charging when its below freezing should be fine as well.
    I'm in the same situation with the car outside.
    jerrymildred and Darien Day like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I've charged outside in the rain hundreds of times. Never had an issue. Living in FL, I don't get many opportunities to charge in the snow. But on a winter trip to Ohio in my PiP, I charged in single digit temperatures and occasional snow. The only concern is that you could get freezing rain and that will complicate unplugging from the charging port.
    Darien Day likes this.
  4. Ovation
    Ovation Active Member
    156
    130
    Quebec
    I’ve charged in rain, sleet, freezing rain, snow—all with the Toyota charger plugged into my front porch. No issues. I did get a locally made port cover (quite sturdy) to avoid chipping ice buildup out of the port space but I’ve done nothing to protect the other end. Toyota tells me it’s sturdy enough for Canadian winters—who am I to argue?
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Absolutely no problem with outside charing in inclement weather. The only time you may want not to connect the charging cable to the car is when there is active lightning nearby. But this precaution is even for the cars charged inside a garage.
    Freezing rain is no problem, but you may want to invest in an EV charge port cover mentioned by @Ovation as shown in the photo.
    Without the port cover, it is a bit of work to close the port door after charging.
    #5 Salamander_King, Dec 23, 2021
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    jerrymildred likes this.
  7. Ovation
    156
    130
    Quebec
    AC27F1FF-060B-4B52-B269-8C42D1F25746.jpeg This is my cover (photo from manufacturer ÉcoSolaris)
