Parking pawl problem?
Discussion in 'Gen 4 Prius Main Forum' started by pilotgrrl, Jul 21, 2018.
Tags:
  1. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    My 2016 Three w/Advanced Tech Package seems to have a parking pawl issue. It is now rolling back about 6"/15.24 cm after I place the car in Park.
    It used to roll back only about 1"/2.5 cm or so.
    Is this a parking pawl problem or something else?
  2. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    If I park on a slight incline, mine rolls back a few inches. But that's only because I was STUPID and didn't apply the PARKING BRAKE first. On flat ground, no roll back, but I usually always step on the parking brake. (20 guys! will respond and say they've NEVER used the parking brake in their life!!:ROFLMAO: Too lazy, I guess.)
    I just don't like the "feeling" of the car's weight resting on the pawl.
    #2 Starship16, Jul 21, 2018
    Tande, davecook89t and HPrimeAdvanced like this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Manual says to always press the foot parking brake before turning the engine off. P will be activated automatically when you turn the ignition off. Nobody should be relying on P alone to keep the car stationary. It's not designed to be used on its own. P is a backup and supplementary to the foot activated parking brake.
    Pixel 2 ?
    RCO, Starship16, krmcg and 1 other person like this.
  4. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I ALWAYS use the parking brake!! Look at the actor (Anton Yelchin, Star Trek) who was run over/killed by his own car! Safety first, kids!!
    AChoiredTaste.com
    Starship16 and krmcg like this.
  5. The Professor
    598
    809
    UK
    Excel
    But to answer your question... Not sure if 6" is bad or not. P has to take up all the slack in the system, all the way from the eCVT, to the flex in the rubber on the tyres. Mine certainly moves somewhere between an inch and maybe 4, but as this had only happened to me on the rare occasions I've forgotten to apply the foot parking brake, it could well be more under some circumstances.
    Pixel 2 ?
    RCO and krmcg like this.
  6. bisco
    52,807
    unlikely there is a problem. after 14 years of prius, i have found they roll more sometimes than others. not sure what the variables are, maybe where the tranny stops and slope?
    RCO likes this.
  7. ChapmanF
    18,993
    I'm thinking the distance between the cogs under the parking pawl hasn't changed. :) I wonder if you, earlier, just had a run of instances where (when you noticed) the position where you'd stopped was within an inch or so of the pawl meeting the cog, and you later happened to have a run where (when you noticed) you happened to stop closer to six inches away, and that was enough to seem like a real change and not a statistical artifact.
    -Chap
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I tried it a few times today when I parked - one time I feel it was at least 100 mm, but only a gradual down-hill. The other 2 it was more like 20-30 mm. I never use the park-brake in my carport - it's dead level and doesn't move at all.
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I really couldn't say, but logic tells me that it is still working, albeit with a greater distance of travel, so I wonder if it really matters. The pawl itself must be ok, so maybe one of the gates has chipped off (?) if there is such a thing. Then, a loose chunk of metal in the works could present a problem. All critiques welcome as I'm only guessing and ridicule will be allowed. :sneaky:
    alanclarkeau likes this.
  10. alanclarkeau
    7,045
    7,593
    Check this out:
    If you don't want to watch the whole thing (nearly 2 hrs) - watch for a few minutes starting at 24:00
    RCO likes this.
