Part number for rear wheel bearing assembly.
Discussion in 'Generation 1 Prius Discussion' started by Denn Mann, Oct 9, 2018.
  1. Denn Mann
    Denn Mann Junior Member
    Portland, Oregon
    2002 Prius
    Does anyone have the actual part number for the rear wheel bearing assembly for a generation one Prius handy? Any help is appreciated.
  2. Mendel Leisk
    42,323
  3. Denn Mann
    Portland, Oregon
    2002 Prius
    The right rear is failing. So I should be able to order This part number, and swap it out? Do I need seperate sensors as well?
    42450-47020
  4. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I'd probably buy a hub/bearing assembly from Rockauto. An economy one, btw. The ones in Mendel's link seem stupidly expensive. I've been using aftermarket hard parts since the '60's and rarely have any problem.
  5. Mendel Leisk
    42,323
    Timken?
    They might even be the OEM supplier??
  6. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I don't know. The ones that are less than $60 are most likely made in China. There's a big jump in price above $60 tho.
  7. Denn Mann
    Portland, Oregon
    2002 Prius
    Considering that this is the fourth OEM Toyota purchased one, in 158k, I'm not too worried about a Chinese one. The installation looks pretty easy, so I just wanted to confirm the part number.
  8. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
  9. ChapmanF
    19,006
    Do they all come with the wheel speed sensor attached, or is it a la carte for some of them?
    -Chap
  10. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    It doesn't appear that the sensor is included with the OEM, and I didn't see any of the aftermarket ones that included the sensor.
  11. Mendel Leisk
    42,323
    All you would see is a wiring receptor, it's built right in. I'm guessing they all do have it, it's an integral part. But yeah maybe need to verify.
    Brian in Tucson likes this.
  12. ChapmanF
    19,006
    I replaced my Gen 1 right rear with one from the dealer, and it came with the sensor already attached. I'm not sure whether that will be true for all of the cheaper alternatives though. The repair manual does include instructions for how to remove the sensor from the old hub and press it to the new if you have to, but with the dealer hub you don't have to.
    -Chap
    mroberds likes this.
  13. mroberds
    mroberds Member
    143
    59
    2001 Prius
    To second @ChapmanF 's report, I replaced both of my rear hubs with dealer parts (a few months apart), and they both came with a new speed sensor already pressed in to the hub.
    The aftermarket part I considered, I think from Autozone, also came with the speed sensor, at least according to the pictures on their site.
    Looking at my notes, I bought the right hub in January 2013, and the left one in June 2013. They were $250.55 each at the time, before tax. The car would have had about 182,000 and 186,000 miles on it, respectively, when I replaced them. The failed hubs were the ones that were put on the car at the factory in 2000.
