Pascal's wager
Discussion in 'Fred's House of Pancakes' started by daniel, Mar 18, 2012.
  1. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    You did not reformulate the wager at all. You did not offer a formulation for addressing which god to choose. I phrase it as I did because a formulation on choosing which god, or excluding some goods, need not be done as a reformulation of the wager. For example, the argument I p provided of why one can exclude an unjust or inverted "god" from the wager was not a reformulation of the wager, it was its own formulation.
  2. daniel
    14,487
    1,519
    Spokane, WA
    The problem is that there are many Christianities. All share a belief that Jesus was the Christ, and nowadays most, if not all, believe that Jesus was god, though this was not always the case.
    But Christian beliefs regarding the formula for salvation are all over the map. Some believe that faith alone is enough and nothing else matters. Some believe that righteousness alone is enough and nothing else matters. Some believe that both are necessary. Some believe that a modicum of either will suffice.
    It is narrower than that. It's about betting on a particular version of god. Because you can't simply put a $10 chip on "god" on the roulette table. You have to follow whatever rule system you think god requires of you. And since different religions have different rule systems, and many are mutually exclusive, you actually have no way of knowing HOW to bet on god.
    You must first make an assumption regarding what constitutes "betting on god" and hope that your assumption is correct, because a wrong assumption could lose you more than living as an atheist or agnostic.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Message #400. You even quoted it in its entirety once.
  4. drinnovation
    2,027
    586
    65
    CO
    As I said before, I read your post #400 as you just defining god==Odin, infinite afterlive == Valhalla and then added your views about how to win the "wager" for that particular god. Fundamentally still the same wager.
  5. drinnovation
    2,027
    586
    65
    CO
    Can you point out where the text of the wager says a particular god on which to bet? As I said in the rest of the paragraph you cited above. but cut out I don't believe the wager says how to win, just that you should go all in.
    Once you decided to wager, knowing that its all in, then how to win is then up to you to analyze how to maximize your chance of winning. The issue of which god, and which set of rules is not a addressed, and in my view leave the person wagering the task of analyzing which to choose and what it means to follow the appropriate rules.
    Since there are many conflicting choices, in MY case that meant studying a wider range of religions, seeing the common ground/elements and trying to follow them. I presented a piece of that before... which considers the fact the that only evidence is third, forth-one-hundredth hand and effectively ad populum, so I have to weight the statements with the fact that humans have been reinterpreting the data so many times, often with their own agenda/power-base, that it cannot all be taken as gods truth.
    If I imaging gods trying to help us reach enlightenment, maybe they did speak with various people, but they just misunderstood what they hear or later followers adapted it to support their own desires. As an educator I know/see the difference between providing students answers and letting them learn their own from just enough direction and hints.
    If one is unsure about which god, e.g. one that has a finite afterlife or for which the infinite aspects of afterlife is not condition on a special behavior/belief, then maybe you can effectively use the same ante for multiple bets.
    If the bets are mutually exclusive then, in my view, is far more likely the effect of an attempt by human interpreters to control others and build their power base than it is the actual will of any just god. Note this is well outside the original wager, but if I have to go all in on a particular bet I'm free to analyze even weak data to refine my choice.
  6. Corwyn
    2,171
    659
    23
    Maine
    Yes, that was entirely the point. A reformulation for a different god. If you feel that Pascal's wager has merit. You should be following this version as well. If you are not, you are just using Pascal's wager to justify an irrational choice you have already made.
  7. Corwyn
    2,171
    659
    23
    Maine
    Actually choosing which god(s) is pretty easy. Since there is no evidence upon which to make a choice. One should choose that subset of gods for which the largest number can be compatibly met, and which are promising eternal bliss. Choosing in a single jealous god is a terrible strategy, when you can choose hundreds or thousands of gods who each offer a chance.
    OK. not easy. But not a philosophical conundrum.
  8. daniel
    14,487
    1,519
    Spokane, WA
    This is just plain ridiculous!!!
    Pascal's wager states that you are better off to believe in god than not to believe in god because if you believe and you are right you go to heaven, and if you are wrong you lose nothing; whereas if you don't believe you have no chance of heaven.
    Are you really incapable of seeing that this contains multiple unfounded assumptions???
    Are you really so enslaved to your own convictions about what god must want of us that you cannot see that those are unfounded assumptions?
    I think you are just being disingenuous now. You are a very clever debater, but all you've done is try to distract the conversation away from the subject (a common ploy among believers when they try to use reason to justify a belief system which places faith above reason). The subject is not probability theory. The subject is whether or not it is reasonable to assume that belief (or in your terms, "betting" on a god) is the key to eternal life.
    You have no way of knowing which god to "bet" on, or even if the "real" god has EVER revealed himself to anyone.
    You have no way of knowing if the "real" god will accept a divided bet.
    You have no way of knowing if there is a god.
    And critical to the whole foundation of Pascal's wager, you have no way of knowing what constitutes "betting on god." Perhaps what you consider to be betting on god (belief and good works or a righteous life) is actually a bet against god and has exactly the opposite effect of the desired one.
    You can analyse probabilities and limits all you like, but since you do not know whether it is belief or unbelief that actually gets you into heaven; since you do not know whether a life of kindness or a life of cruelty gets you into heaven; since you don't even know whether TRYING to do whatever might be "right" gets you into heaven or gets you into hell; since you do not know any of these things, Pascal's wager is worthless.
    The ONLY way Pascal's wager can work is if you KNOW what it is that constitutes "betting on god." And you cannot know that, though most believers in any religion are certain that they "know" this, and of course they've been murdering each other throughout history over quarrels about who's got the "right" answer.
  9. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    This was beyond ridiculous about 400 posts ago.
    I think the believer's strategy is to talk in circles until the non-believers bang their heads in frustration, lose their temper, and run away screaming. Then, they can say: "See? Heathens are angry, and confused." :rolleyes:
  10. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    You're opinion noted....
    This is mine...
    Agreed, 400 posts and continuing to argue is pointless, yet I predict some will be compelled to continue.
  11. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    I'll bet your prediction is spot-on Bra...
  12. Chuck.
    2,766
    1,510
    ^ believe me, I'd like to be wrong on this one.
    Someone will ignore I've been quiet for most of a week on this thread, yet respond like I've been itching for a fight.
    I'd like to thank Daniel for giving the thread a brief rest last weekend, along with his good will.
  13. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Interestinly, this is similar to heavy-handed methods that Pascal himself
    was not above using:
    "… One of the Apologie's main strategies was to use the contradictory philosophies of
    [ame=http://en.wikipedia.org/wiki/Skepticism]Skepticism[/ame] and [ame=http://en.wikipedia.org/wiki/Stoicism]Stoicism[/ame], personalized by [ame=http://en.wikipedia.org/wiki/Montaigne]Montaigne[/ame] on one hand, and
    [ame=http://en.wikipedia.org/wiki/Epictetus]Epictetus[/ame] on the other, in order to bring the unbeliever to such despair and confusion
    that he would embrace God.[/I]"
    [ame=http://en.wikipedia.org/wiki/Blaise_Pascal]Blaise Pascal[/ame]
  14. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Yup. You got it.
    You show me the church that tells any prospective parishoner "Sorry bub, you're doomed. Don't bother to come here".
    Back when I went to a church the baptismal ritual was a big deal: it "saved" you; once "saved" you were "safe". Nothing you could do would "unsave" you. I thought at the time it was an incredibly childish belief (and still do, albeit much more strongly).
    Look at the Catholic ritual of Confession - how is that anything other than a "Get Out Of Jail Free" card printing factory?
    And they key?
    BELIEVE.
    BELIEVE and god will forgive you.
    All those pastors at the gallows and at the doors to the last room of prison death rows aren't there because they think there's no hope of heaven, even after a lifetime of total and complete depravity.
  15. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, that is interesting. I thought I was just being sarcastic, based on my own experiences.
    So, even an atheist/agnostic/heathen gets in, because they were baptised as a child? Belief alone as a 'get out of hell free' card doesn't make sense to me, either. I'm firmly in the 'actions, not words' camp. And I try to live by it.
    As a side note to Chuck: This debate has raged for millennia, and will likely rage for millennia more. I'm sure you are a nice person who is kind to strangers, children, and other small animals, and I don't dislike you in the least or wish you any harm. I'm discussing and debating ideas, not bullying people.
  16. Chuck.
    2,766
    1,510
    ^ Thank you for the thoughtfull reply....I also give you the benefit of the doubt in general...my last post was not directed at you, although I was quoting you.
    I hope the course of this thread for most part the past week is the rule.
  17. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    You can be in the debate, or out, but none of us has any hope of ending it.
    I think Daniel has the patience of a saint. :p
    Thank you, Chuck, for giving me the benefit of the doubt as well. Even though I strongly suspect that the beliefs you hold probably tell you that I'm going to hell. Please correct me if I'm wrong about that.
    And if it's any consolation, you'd never know my beliefs by my actions. The assumptions people make can be quite astounding.
  18. Chuck.
    2,766
    1,510
    ^ I believe in a lot of bad outcomes - including Hell, but do I wish them on anybody?
    Hell no. ;)
  19. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Oh, thank heavens. ;)
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You can go to Hell, but you don't have to.
