Passenger airbag indicator is not illumated
Discussion in 'Gen 2 Prius Main Forum' started by beauxarts, Mar 4, 2014.
  1. beauxarts
    beauxarts New Member
    Incheon, Korea
    Hello
    Passenger air bag indicator is not illuminated
    I replace indicator lights. But still not work
    Is this the airbag module problem?
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    on my car, it only lights up when someone is sitting in the seat.
  3. beauxarts
    Incheon, Korea
    My car is No light on/off both.
    Just "passenger airbag" light is illuminated
  4. JC91006
    16,930
    8,640
    This seems normal, sit on it and see if it changes
    SM-N900P ?
  5. beauxarts
    Incheon, Korea
    But in my car,
    It doesn't change no matter who sit on it
    Thanks
  6. JC91006
    16,930
    8,640
    You would have to test the sensitivity of the seat scale. You would need techstream or similar software to connect to the OBDII system to test the system.
  7. beauxarts
    Incheon, Korea
    Thanks
    Today, I heard my car has a problem about airbag module and pressure sensor!!!
