Passenger Door Rattling
Discussion in 'Gen 3 Prius Main Forum' started by mwok86, Sep 27, 2010.
  1. mwok86
    mwok86 New Member
    203
    16
    usa
    After traveling on the prehistoric roads (99% of the roads) in DC that have not been maintained since the Stone Age, the front passenger door is rattling (or something in it/within the vicinity) at only 3000miles. It looks like this happened after I started driving on the beltway. The beltway has less potholes than the prehistoric roads BUT on the beltway, you'd be hitting those potholes at 65mph.
    It sounds like it's the door window?
    Is it an easy fix? Will the dealership take care of it for free next time I go in for service?
    Would bigger tires "absorb" the impact better? I tried to find 5 other alternate routes, what a mistake! Those routes were actually worse than the 2 alternate routes I currently use.
    What's funny is that they are actually expanding a sidewalk on a extremely poorly maintained road that has 2 narrow lanes. The lane markers are faded and the lanes have become extremely narrow. The expansion of the sidewalk actually makes the lanes EVEN more narrower.
  2. creativeguy
    creativeguy Member
    301
    17
    CA
    Same here. It is probably more of a "tick-tick-tick" sound than a rattle, right? I'm pretty sure that it is the black door gasket in the upper window area. I've got the same problem on my CR-V too. When I push on the window, the ticking stops. The fix seems to be lubricating that gasket, and there are posts out there that tell you how to do it.
  3. mwok86
    mwok86 New Member
    203
    16
    usa
    Nope, it's more of a light rattle. It's Toyota's fault for not designing the suspension/structure system to absorb impact from prehistoric roads. In Japan, they might not need that system but over here they do.
  4. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Do you have a front passenger? If not, it could be the male seat belt clip for the passenger rattling against the door post on the belt. I discovered this by accident. Just pull the clip up as high as it will go and see if that stops the noise.
  5. crabbyman
    crabbyman Member
    79
    30
    Hate to dig up an old thread..but did you ever figure out your noise? I have a similar noise. It sounds like something lose inside the door or as if the door sheet metal is flexing badly.
  6. bisco
    49,482
    are you still under warranty?
  7. crabbyman
    crabbyman Member
    79
    30
    I believe I am. It is just it sounds like they may just make it worse the way it sounds from all these posts.
  8. bisco
    49,482
    i can't deny that, but your only alternative may be to pull the panel off yourself.
    maybe take the service manager for a ride and see what he hears sitting over there.
