Passenger Door won't open from outside. Fine from inside
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Whirlyball, Oct 5, 2021.
  1. Whirlyball
    Whirlyball New Member
    Ann Arbor, MI
    Just bought this 2012 Prius IV yesterday. It seems to be top of line with every option installed. Discovered today the following about passenger front door:
    1. Once locked, it will not open from the outside even it if it unlocked via FOB, inside unlock buttons, or inside lock toggle
    2. It opens fine from the inside
    3. Once open from the inside, the outside handle works fine again until the door is once again locked
    Kinda bummed that this is day 1 with the car. Hoping maybe it is user error. Otherwise the car is pristine and in like-new condition for a 9 year old car.
    Any suggestions are welcome and appreciated.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Sounds like the lever inside door got detached
    Whirlyball likes this.
  3. Whirlyball
    Ann Arbor, MI
    I cannot fix this myself. Any opinions if it needs to be a dealer job or local shop could do (or estimate of what it might cost)?
  4. ChapmanF
    15,562
    Probably a simple job for a local shop. If it were mine, taking the trim off the door and getting my own look-see would be my first inclination.
  5. Whirlyball
    Ann Arbor, MI
    Turned out to be the actuator. Local shop put a used one in from the parts-yard (2014) and all good now ($360 later).
  6. bisco
    49,435
    wow! how much is a new one?
  7. Whirlyball
    Ann Arbor, MI
    $550 from Local Shop and $600-700 at Dealer.
