Passenger headlight suck on high beam!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by austincalvello, May 12, 2016.
  1. austincalvello
    austincalvello New Member
    los angeles
    So I had an issue with my hid lights, I replaced one ballast and 2 new bulbs and they work fine now but the passenger side is stuck on high beam. When i turn on the brights only the driver side gets brighter, does anyone know how to fix this? I only replaced the driver side ballast
  2. S Keith
    S Keith Senior Member
    799
    331
    AZ
    2003 Prius
    HID are actually only one "filament" High/low is governed by a mechanical shifting of the reflector inside the light. Double check that you didn't bump a connection or leave one loose.
  3. austincalvello
    los angeles
    Interesting! Maybe the bulb isn't seated inside the headlight right?
  4. S Keith
    799
    331
    AZ
    2003 Prius
    Sounds like a possibility
  5. booi
    booi Junior Member
    San Francisco
    I am also having this problem, did you find a solution?
