"Passenger" light always on
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by coder, Feb 4, 2015.
  1. coder
    coder New Member
    2015 Prius c
    Owned my Prius for 4 days and this doesn't seem right to me.
    My "Passenger" light is always on, even if no passenger (or object) is in the seat. The airbag on/off indicator is also always on and picks on or off correctly.
    I would expect that this light should be off unless a passenger is detected and then it would also show the on/off indicator.
    I asked the service guy if this was normal and he said yes.
    Can anyone verify that this is proper behavior?
    Thanks!
    52,762
    pretty sure there's a thread here with a solution. electric tape over the light.
    coder likes this.
  3. coder
    coder New Member
    2015 Prius c
    Ha! That was going to be my solution as well. I hate stuff showing up that's not telling me something useful (to me).
    52,762
    the other guy was embarrassed when his friends asked him why the light was on.
  5. fuzzy1
    10,687
    That would make the 'off' indicator useless, as it would never be lit.
    What does the owners manual say?
  6. coder
    coder New Member
    2015 Prius c
    It would be lit if there was a small passenger.
    I haven't completed reading the manual yet, but I did look for this specifically and didn't find anything.
  7. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    Covering the Passenger Airbag|ON|OFF sections with electric tape is a 30 minute job. It's one of the main gripes with this car. Pretty telling that that's all we have to complain about.
    coder likes this.
  8. fuzzy1
    10,687
    Is the existing sensor capable of that?
  9. coder
    coder New Member
    2015 Prius c
    Yes. If a light person is in the seat, the "airbag off" indicator will be on. If it's a normal weight passenger, then the "airbag on" indicator will be on. This is all good and proper, but if no one is there at all, I'd like for all three to be off.
    My main concern was that mine wasn't working correctly. Now that I know that it is I'll either get used to it or tape it.
  10. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    2006 and newer Prii have that light which does stay on all of the time. I think it's pretty silly, but that's the way it is.
    Avi
  11. fuzzy1
    10,687
    I'm not aware that the sensor has three states (no passenger weight, light weight, heavier weight), instead if just two states (under threshold weight, over threshold weight). What leads you to believe the former case?
  12. coder
    coder New Member
    2015 Prius c
    I misunderstood your question. Yes, there are only two states.
