Passenger Rear Door Weatherstripping
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by prevee5, Sep 14, 2020.
  1. prevee5
    prevee5 Member
    122
    Monrovia, California
    Anyone have the rear passenger door weatherstripping fail? The front edge of my passenger rear door rubber seal has disintegrated and half has fallen off. Anyone have this happen and is it an easy fix?
    This is a piece of rubber seal that covers the area in front of the door frame along the window, attached to the door, Maybe 14” or so. A bit of this rubber part is visible from outside the car when the door is closed. This is Not the seal that goes all the way around the door.
    I can hear a bit of wind noise from this area.
  2. prevee5
    prevee5 Member
    122
  3. Tourswag
    Tourswag Junior Member
    Arizona
    2013 Prius v wagon
    Yes mine has failed one side has perished into a weird tar- like goo on the door.
    75978-47050 ( driver side) and 75977-47050 ( pass side)
    Mike
  4. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    That's exactly what happened to all four rubber trim strips that keep rain and trash from falling down past the window into the door on my 3rd-generation regular Prius.
  5. Tourswag
    Arizona
    2013 Prius v wagon
    The part numbers i posted above came from the dealer- these are incorrect.
    as I posted in another thread the dealer says they don't show on his parts diagram...
