passenger side headlight randomly going off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tim zheng, Sep 28, 2018.
  1. tim zheng
    tim zheng Junior Member
    16
    new york
    Started with the passenger side headlight randomly going off while I was driving. Turning the lights on and off would fix the problem but it would soon go out again. how to fix it
  2. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Change the bulb.
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Wrong bulb the end pin is slightly shorter HID I assume
  4. JDonovan
    JDonovan Junior Member
    CT/PA
    There is an entire thread dedicated to this issue. I thought it was just my car (2005) ..started with my passenger headlight, and now either headlight will randomly go out, sometimes BOTH....I've been pulled over 4 times in that last 6 months! I'd suggest reading the important information in those threads. I filed a complaint with NHTSA today and will take some of the other measures suggested.
  5. tim zheng
    16
    new york
    that's prius problem ,lot of these cars same problem,and never fix it for free......
  6. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I had that happen it ended up being time to replace the bulbs.
    iPhone ?
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    This is not a complicated issue. Install new bulbs. Both of them. Don't install some cheap chinese knock-off junk that you get from ebay or amazon for 10 bucks. Your 2005 (with HID lights based on your avatar) requires D2R model bulbs.
    Don't blame toyota, as this is most likely your fault. You've probably had one already going bad (blinking off) and never recognized it. Once the second one started failing, it appears as if both lights suddenly failed. Welcome to the world of HID headlights.
