Passenger-Side Mirror
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Zteve, Jun 4, 2023.
  1. Zteve
    Zteve Junior Member
    2018 Prius
    Does anyone, besides me, think the passenger-side mirror makes cars in the adjacent lane appear much further behind than they really are? The cars are actually very very close, so close that I think it's dangerous to pull back into the adjacent lane. I don't rely on the mirror anymore for changing lanes after passing.
    Vision out the back window is impossible, of course, so I'm thinking of gluing a flat mirror onto the stock convex one.
    Comments? Opinions?
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Typically, passenger side mirrors on cars have a different magnification than the driver's side mirror. This is done to provide a wider field of view on the passenger side, which helps to reduce blind spots and improve visibility for the driver. This improves safety, not reduce it.
    If you're coming from an older style of mirror then there is some learning to be done and time spent getting used to it. Mirrors on every car I've ever driven in the US in the past 25 years (I'm from the UK) have always had printed on the bottom something to the effect of "Caution: Vehicles appear further away than they really are", or something along those lines, to remind drivers of this.
    The passenger side mirror is often more convex (wide-angle) than the driver's, to compensate for it being further away from the driver than the driver's mirror. The further you are away from a mirror, the less the field of view so the mirror compensates for this.
    The different magnifications of the two mirrors help to optimise the overall visibility and safety of the vehicle.
    On some vehicles and in some countries, the driver's side mirror often has a variable and increasing convex curve is it gets towards the outside edge, providing very distorted views of vehicles in that area of the mirror, but it also allows cars in your "blind spot" to be somewhat visible, which again improve safety as being able to seem them a bit is better than not at all.
    So with the mirrors, it's more a matter of getting used to them and understanding them, rather than them being unsafe.
    Give it a while, but if it continues to be an issue then you can get different third-party glass for them, but be mindful of things like the heaters in them if your car has them. You can also get mirrors that stick or extend them, but these can be equally annoying.
    The rear visibility is generally worse as cars become more aerodynamic and/or longer, purely because the field of view narrows as both of these increase. There's no great solution to this, short of using extended side mirrors, adding an always-on rear view camera (you can get ones that turn your main mirror into a screen), or swapping vehicle shape.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Not a problem for me, just as @The Professor says, it is a convex glass to give an improved field of view.
    I don't have any issue looking out the back at all, in fact I find the rear visibility far better then a Model 3 I drove a while back.
  4. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
  5. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    I don’t remember exactly which car I bought that first had these mirrors, but I remember a new 1979 Chevy Caprice Estate wagon that had them! So you would be coming from a pretty old vehicle here in the states to be experiencing them for the first time!
    As far as rear visibility, the Prius pretty much beats any car I’ve ever had, except for the station wagon and an Austin Healey convertible!
  6. Zteve
    Zteve Junior Member
    2018 Prius
    Thanks for your replies, really, but I pretty much disagree with all of them (n)
    I'm 83, so my expectations were shaped a long time ago. Still, my last cars had convex mirrors, too, but they didn't make the adjacent cars appear to be so close. For my money, the Prius's are simply too deeply curved. If they were less curved, the cars wouldn't appear to be so close. Maybe mine are at the extreme of the permitted curvature.
    Anyway, I found a number of replacement mirrors on Amazon in all sorts of configurations--curved and flat, heated or not, with the blind spot warning or not. I'll install a flat one and see what happens.
    Thanks again.
  7. Zteve
    Zteve Junior Member
    2018 Prius
    So I replaced the side mirror. It's flatter than the Toyota mirror, so that's good. The mirror is useful now.
    The motors moving the mirror work, but the Blind Spot Monitor doesn't. It needs to be reset. Can I do that with Carista? Should I go to a Toyota dealer or to a body shop instead?
  8. Zteve
    Zteve Junior Member
    2018 Prius
    In both Carista and Car Scanner, the control for the passenger-side mirror is displayed with a Reset button, but selecting the button doesn't restore the BSM system.
    What now?
  9. Doug McC
    1,087
    428
    Midwest
    2022 Prius
