Passenger side window not operable from drivers side anymore
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by szgabor, Jan 27, 2014.
  1. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Passenger side window not operable from drivers side anymore, with the respective button. However, the windows does work when I try from the passenger side.
    This only started after the deep freeze ...
    Is this under warranty? I hope I am at about 13k and 13 month with this 12' Prius 2
    It also seems, but I can not be sure that the little green led shines dimmer than the other three.
    Is it worth trying something DYI I really do not want to go in for a service
    Cheers
  2. JC91006
    16,480
    8,397
    your warranty should be the basic 3 year/36k mile warranty. You should be covered
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Sounds like that switch on the drivers side is bad. If the warranty does not cover, swap it with one of the others to verify before you spend the money for a new one.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Someone activate the child proof button? H
  5. szgabor
    993
    175
    Oceanside NY
    I tried to toggle that but by definition even if you have that the driver button supposed to overwrite that and again it work from the passenger site ... wouldn't it be the opposite ???? if I engage the child lock button only driver can lower and raise the windows ??? that is how I imagine it wold work
  6. frodoz737
    4,297
    2,348
    33
    Check your switch. Just swap the harness/ plug over and you will know.
  7. El Dobro
    El Dobro A Member
    6,978
    3,213
    It's covered under the 3/36 warranty. I'd bring it to the dealer first since you paid for the warranty when you bought the car. ;)
  8. bisco
    49,437
    correct.
  9. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    i noticed the other day in my 2010 the the switches on the driver door panel were difficult to operate, like they were bound up... it was incredibly cold. but once the car interior warmed up they were fine.
  10. Maj
    Maj Junior Member
    Orlando, FL
    I also had non-responsive passenger side windows from the master console. I was given this solution by Toyotechwv:
    Go to each door switch and roll the window down, hold switch down for a sec, roll window up, hold switch up for a sec.
    Worked for me and only takes you a few seconds to try.
  11. szgabor
    993
    175
    Oceanside NY
    UPDATE...
    After last night big freeze .... I tried again and it now works ... this is puzzling ... I know it was NOT working yesterday during the snow storm...
    I did try what Maj suggested last week but did not seem to have any affect.
    But this morning after a 2hours drive it worked.
    Go figure !!
