passive solar apartment with solar hot water
Discussion in 'Environmental Discussion' started by galaxee, Mar 12, 2007.
  1. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    well, here's the part i was afraid of. summertime in the south. outdoor temps have been well over 100 all week, yesterday it was 105 at 6pm. our outdoor thermometer said 110 was the high it measured yesterday, and the lows aren't too low: it was 89 when i got up at 8 this morning.
    so we're using the a/c unit pretty much continuously. we used it quite a bit in july, and our bill came in at 11 KWH/day. i am wondering what it'll be like this month with these horrible temps.
    the a/c unit is pretty good about cooling the place, we had trouble at first because there is no airflow in the hallway to the bedrooms, and the circulating fan takes air from around the corner from where the a/c output goes. a simple $15 box fan fixed that. that plus a standing fan in the bedroom at night and we sleep just fine. we keep the house at about 78, and the auto a/c setting isn't running at all times.
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    It's that damn humidity. Traps the heat. That's one nice thing about the heat in the west. It's pretty dry and at night things cool down a bit.
    11 kWh/day isn't bad. It's not amazing, but not terrible. Good luck getting through the rest of the summer. At least Fall is around the corner (kind of).
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    <div class='quotetop'>QUOTE(txav8r @ Mar 12 2007, 10:50 AM) [snapback]404285[/snapback]</div>
    NO IT DOESN'T HELP, BECAUSE YOU ARE OH SO WRONG!!!!! <_<
    They:
    * are more convenient and accurate than manual thermostats and improve your home’s comfort
    * contain no mercury
    * save energy and save money on utility bills — when used properly, about $150/year
    * are better for the environment, since using less energy helps reduce greenhouse gas emissions associated with energy production
    http://www.energystar.gov/index.cfm?c=ther....pr_thermostats
    If for some reason you feel this is some conspiracy concocted by the US EPA and DOE, then check out these links . . .
    http://www.oldhouseweb.com/stories/Detailed/10261.shtml
    http://community.gaiam.com/gaiam/p/ThermostatMyths.html
    http://www.ccicenter.org/archives/62
    http://www.oznet.ksu.edu/news/sty/2002/hea...costs102502.htm
  4. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    <div class='quotetop'>QUOTE(tripp @ Aug 14 2007, 04:01 AM) [snapback]495273[/snapback]</div>
    Total electric bill, or just AC ?
    If it is total, then mine is 3 fold.
  5. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(EricGo @ Aug 30 2007, 01:28 PM) [snapback]504439[/snapback]</div>
    Total. The national average per house hold is something like 700 kWh/mo, I think. We use anywhere from 279 - 550 kWh/mo for a family of 4 in a 1300 sqft house. But... we have a swamp cooler, not an AC, so it's a lot easier for use to achieve those kinds of numbers. Our avg monthly use is probably somewhere around 425 kWh, I should figure that out sometime.
    Actually, 11 kWh/day would be pretty good for the AC alone in a hot climate, that's what, 330 kWh/mo (assuming 30 day month). THat's pretty good. From looking at my parents energy bills, it seems that ACs can use way more than that.
  6. galaxee
    9,810
    469
    MD
    11 total. keep in mind this is probably a 750 sf apartment.
  7. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(tripp @ Aug 30 2007, 02:49 PM) [snapback]504458[/snapback]</div>
    Is that right? I've performed comparisons on our water use and we fall waaaay behind average water consumption per capita. I was always curious about our electrical usage but never did the research. For 8 months of the year, we use 250 kwh per month. In Dec, Jan, Feb and March we use anywhere between 375 kwh per month and 500 kwh per month.
    So we do well on our electrical use and water use in comparison to averages but I'm certain our gas consumption in winter would put all of you to shame. I just can't seem to get that one righted.
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(SSimon @ Aug 30 2007, 03:32 PM) [snapback]504545[/snapback]</div>
    Back when I lived on the frigid prairies of Western Minnesota, we finally got a handle on our fuel oil consumption when we completely insulated, sided, and then put new vinyl windows on, our 1914 farmhouse.
    It was absolutely amazing, the difference!
    All the caulking, plastic over the windows, and draft stoppers could not compare to putting new siding and windows in. I think it was because the did the house wrap stuff before putting the siding on... oh, and we did the blow-in insulation.
    One fabulous, warm and cozy winter there... and then I moved away.
  9. SSimon
    1,426
    N/W of Chicago
    I've done all low cost improvements to be recognized and did one higher cost improvement, which was attic insulation. The gas co. says we're down around 40% from where we were but our use is still way high. My sister has a house much bigger than mine with four levels (basement, split level first floor and upstairs) and she pays less than half of what we do.
    Siding and windows are the last fuel efficiency improvements to be implemented and they're too costly for us right now. So we're forced to grit our teeth four months of the year.
  10. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(Rae Vynn @ Aug 30 2007, 05:20 PM) [snapback]504564[/snapback]</div>
    What town? I used to go out there every so often on Geology field trips when I was in college.
  11. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(tripp @ Aug 30 2007, 07:05 PM) [snapback]504658[/snapback]</div>
    The farmhouse was 4.5 miles south of Kensington.
    Kensington is along Hwy 55, about 20 miles southwest of Alexandria. You probably were around Glenwood, right? With the glacial potholes?
  12. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(Rae Vynn @ Aug 30 2007, 08:10 PM) [snapback]504662[/snapback]</div>
    There (Glenwood) and Morrison ("Don't take it for granite, it's gneiss"). I also went out to Worthington to play hockey (against a team for Iowa) once. We looked at some other pot holes, but they were along the St. Croix river, not too far from the Cities.
    I loved my time in Minnesota, lived there for four years. I don't know if I could take the humidity there now (even though I grew up in coastal GA). I was back in Iowa recently for a regatta and the humidity about killed me. :rolleyes:
  13. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(tripp @ Aug 30 2007, 07:27 PM) [snapback]504674[/snapback]</div>
    My boss got his degree in geology. I'm going to take that groaner of a pun, and hand it to him :lol:
    I spent 25 years in Minnesota (born a California girl)... and if I never see it again, that's fine... Washington state suits me pretty well :)
