Pat Sparks drives the Gen III at the Australian Media Launch, Sydney.
Discussion in 'Gen 3 Prius Main Forum' started by patsparks, Jul 11, 2009.
  1. Tideland Prius
    16,559
    Thanks for the write-up, Pat! Sorry that you had to wait for so long but I'm sure it was worth it. Nice ot know that the HUD works well.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    The spare tyre space is still there, the tyre pump and repair gunk is in its place. Remove the repair kit and install the spare, jack and wheel brace from a base model and you're in business. In an urban environment a repair kit would get the job done so I don't see a need to change the repair kit for a space saver spare in a cab.
    The reason for the lack of a spare is mass (weight), nothing else.
    Bob, Thanks for putting the graph together.
    Everyone used the same car, it had the timing gear in it.
    The car was warmed up from prior runs and orientation runs.
    The course was about 700 metres from gate to gate.
    The rolling start was a 90 degree turn on the end of the course, maybe 30 to 40 metres. I had the car up to speed from a standing start in this distance. Hey, there's a point, the traction control was really good! No power cutout and it was wet!
    The very slow driver only had a learners permit not a full drivers licence.
    The equipment in the car was used to time the run and track the fuel consumption (CO2 emissions) and send the information from a laptop that Graeme was holding, to a command centre with a display for others to watch progress.
  3. patsparks
    10,664
    567
    That was the right way to get underway, but then like I drive around town, fixed speed!
  4. Flying White Dutchman
    4,376
    313
    he pat
    i see you got a yukon.. hybrid ofcourse:p:D.
  5. patsparks
    10,664
    567
    You like my Yukon? I had a bet with Malorn and lost, so I had to have a gas guzzler for an avatar for a month, so I figured a deceptive hybrid monster commuter truck was the way to go.
  6. Flying White Dutchman
    4,376
    313
    sure ik like it:D ( NOT ):)
    good find that yukon, on your lost bet.:p
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is awesome Pat! :)
    Thanks for the post mate!
  8. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    OK, so the base model still has the spare. That will be fine as I only intend buying the base model - 60K for a cab is not economically viable in Sydney.
  9. patsparks
    10,664
    567
    I thought you were going for a pretty flash cab looking at the i-Tech.
    Yep, base still has a spare because without the solar roof there is no mass issue.
  10. patsparks
    10,664
    567
    Bob, great graph.
    Can you do something for me though?
    Could you add score lines, that is lines across the graph which represent the same score along the line. If anyone can do it you can.
    Thanks bloke.
  11. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    I have a spare, a solar roof and a mass issue.
    Wayne
  12. hill
    8,808
    oh don't worry about Pat ... he'll get 56mpg too ... once he learns to stop dragging his feet :cool:
  13. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    I plan on having a mass issue after this weekend when the new Prius is launched in Australia and we FINALLY get our new I-tech without a spare!
    That will be rectified as soon as I spend the necessary $300 next week for a temporary spare, jack etc to make it complete and in a condition where my wife and I are confident to drive it anywhere.
    We had a kitchen knife pierce and destroy a near-new tyre on a previous car not far from home in the suburbs a little time ago, and a pressure-pack can of sealant and a compressor will not fix that sort of damage! Nor do roadside assist carry Prius-spec wheels all the time to replace a damaged one by the roadside.
  14. patsparks
    10,664
    567
    Was the spare tyre original or did you add it yourself Wayne?
    Hey, did I congratulate you on getting a 2010 Prius?
    Good on ya bloke.
    Next time I come over I'll have to see if there is any more hip room in the back seat Wayne.
  15. bwilson4web
    16,218
    I could add the score points but there is insufficient information to plot the iso-score, graph lines.
    What you are asking for are parameter lines that map boundaries between different scores. To draw such lines, I would have to derive the formula that was used to calculate the lines. Now ordinarily, this is a trivial task using say a second-order polynomial with two variables, speed and CO{2} (the first approach I would use):
    x - velocity
    y - CO{2}
    z - score
    z = A*(x**2) + B*x + C*(y**2) + D*y + E
    I'll leave solving the coefficients as an academic exercise but note that the general solution would treat the powers as variables. It would be easier to contact the organizers and ask,"What was your formula for calculating the scores?" <grins>
    But plotting the iso-score lines gets a little ... ugly. Hopefully, the score points are good enough. My eyes tell me they weighted CO{2} higher than speed or possibly used just a linear scale for the speed offset instead of least-squares penalty. But the low speed driver brought home how much easing on the speed improves the CO{2} score.
    ps. You may need to 'refresh' the browser to pickup the updated graph.
  16. patsparks
    10,664
    567
    The score is simply calculated (CO2 X seconds), I would have thought that would be a diagonal line from top left to bottom right sort of thing? Maybe I'm over simplifying this thing?
  17. ZTrekus
    ZTrekus New Member
    22
    Australia
    I have also given serious consideration as to whether to put my own spare wheel in the i-Tech when I get it. I think I will probably decide not to do it on the basis that if the repair kit doesn't work - then what the hell, I will just drive the mother on the flat tyre to the closest tyre shop - how bad could it get, one wrecked wheel? If in the country though, that worries me - a tow truck out there - impossible.
    What would you do Pat Sparks?
  18. bwilson4web
    16,218
    <GACK>
    The x-axis is velocity so we have:
    v = distance/time(hr)
    time(hr) = distance/velocity
    score = CO{2}*time(sec)
    score / CO{2} = time(sec)
    score / (CO{2}*3600) = time(hr)
    score / (CO{2}*3600) = distance/velocity
    score = (CO{2}*3600*distance) / velocity
    There is enough information to plot the curves. I'll have to hack it up later tonight.
  19. FireEngineer
    1,247
    124
    Both my spare tires are original!! I'll let you sit up front next time, and I'll get you your own steering wheel for your side, too.
    Wayne
  20. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Then he'd be driving down the road, doing this:
    2 people like this.
