PCS Indicator Suddenly Lit - Can't Find Enable/Disable Button
Discussion in 'Gen 3 Prius Technical Discussion' started by tommygun, Mar 25, 2012.
  1. tommygun
    tommygun Who was that masked man?
    35
    New York City
    I've got a new 2012 Model 5. The PCS light came on last night for no apparent reason. Page 304 of the manual says that there is a button under the dash to enable/disable the PCS system. I figured I would try it, but I can't for the life of me locate it down there. Suggestions?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Maybe you pushed it by accident? The light actually comes on when it's disabled. It's located rather far down on the left panel containing the mirror controls, dash dimmer, etc.
    If this is not the case, why would you want to disable it? Get it fixed under warranty.
  3. tommygun
    35
    New York City
    You're right. I'm assuming that somehow it got pushed by accident. I see no reason to deliberately disable it. I haven't had a chance to look again, but the manual indicates it's to the right of the steering column so I didn't really look on the left side. I guess they made it difficult to find so that people wouldn't be tempted to fool with it. Thanks for your help.
  4. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Hard to say from the picture, but it doesn't look like it's to the right of the steering column. More like behind the OBD II connector. I don't have a 2010 V so I can't look for myself.
  5. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    It's not the best picture, but it's located more like directly under the steering column. Duck your head low enough and you should be able to see it. I think it's right next to the TPMS tire pressure "SET" button.
  6. tommygun
    35
    New York City
    You are exactly right. It was somewhat to the left of the steering column, adjacent to the "SET" button. Which leads me to ask, is there any ill effect from having pushed the SET button while searching for the PCS switch? I hope not.
    Thanks again.
  7. RRxing
    2,519
    1,790
    NEPA
    Not really. All the SET button does is reset the TPMS for your current tire pressures. The TPMS light will come on if the pressure drops ~8 psi or so from their current SET pressure (I forget the exact number or percentage.) Next time you check and adjust your tire pressure, press the SET button again.
  8. Tideland Prius
    16,128
    The PCS button just switches the PCS Braking off. The PCS seatbelt and PCS Brake Assist will still work.
    No harm pressing the SET button. Like RRxing said, it just sets the tyre pressure so the computer knows when it's low (I think it's 25% below the set pressure which is about 8 psi based on the factory 35/33 psi setting).
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    To reset TPMS the vehicle must be stopped, turn the power switch ON and push the SET button, wait for the light to blink 3 times. Then wait "a few minutes" and turn the power switch OFF.
    I did mine last time I had the tires replaced and I had to do it a couple of times before it worked. Pushing the button by accident won't reset it.
  10. hunter599
    hunter599 Junior Member
    pakistan
    So pcs light is on but i cant locate the switch its not in the place it should be its jdm prius Rhd
