PCS Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GAM, Nov 27, 2009.
  1. Jenny2010Prius
    Jenny2010Prius Junior Member
    37
    Calgary
    2024 Prius Prime
    SE
    Any update?
    I just had the same issue after DIY servicing all the brakes including brake fluid bleeding. Pressing the PCS button on & off a couple of times got rid of the light & warning message.
    However, considering Prius' PCS system is not even effective in many cases (I lightly rear-ended a vehicle in front of me last November and PCS didn't do anything to stop that), I won't worry too much even if that light is on.
  2. Tideland Prius
    16,668
    Unfortunately, the 2010 Prius' (well Gen 3) is an early version of PCS and will not completely avoid the collision.
    You'll have to get the 2016 and newer with TSS-P to get a system that can actually avoid a collision under 40km/h (for vehicle) and 30km/h (for pedestrian)*
    *Under most circumstances. Of course there are limitations.. blah blah blah..
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The "best" limitation is ignoring deer (because they are not people, and I guess it's ok to hit them?). ;)
