pcv hybrid battery codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Mar 3, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    88
    central florida
    while replacing water pump, i decided to change pcv...
    while doing that to minimize safety issues with orange cable, i disconnected the hybrid switch behind the back seats (i did not disconnect the 12v battery!)
    while trying to get pcv out, i used large strokes on the socket wrench brushing up against the hoses and cables in the area
    started car, getting hybrid warnings with most warning lights going on
    car will not allow me to put in D or R to move he vehicle
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Does the car get to ready and is the orange safety plug seated correctly?
    tankyuong, m.wynn and Muneeb like this.
  3. Muneeb
    Muneeb Junior Member
    22
    23
    SURREY
    Business Edition
    Its your orange plug not plugged in properly. If still doesn't work try disconnecting 12v battery.
  4. Ben Schneider
    88
    central florida
    Orange plug seems to be seated properly
    Going to check ready
  5. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Based on the above pic, ready isn’t illuminated;).
    There are three motions slide it in, throw the handle and then lock it.
    Good luck and keep us posted (y).
    m.wynn likes this.
  6. Ben Schneider
    88
    central florida
    seems either it was a mildly loose hybrid cable and / or the fact that i did not disconnect the small battery before the hybrid...
    seems to be working now.
    thank you for your help and efforts.
    Raytheeagle likes this.
  7. Ben Schneider
    88
    central florida
    maybe the orange plug played a role too...
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    That’s my bet(y).
  9. Ben Schneider
    88
    central florida
    i had suspected the orange plug and took it out and put it back in about 5 times without success until the end when i first disconnected the 12v battery... also was pushing together hybrid connector under the engine so that it would be more likely connected if it was not already
