PCV location
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pyrotalk, Jun 15, 2015.
  1. pyrotalk
    pyrotalk Junior Member
    Please post a picture of the PCV location on my 2010 prius. I tried replacing but never found the damn thing.
    thanks
    m.wynn likes this.
  2. Mendel Leisk
    42,355
    I found this on a forum, saying it's incorporated into the valve cover. Seems plausible, there's a large hose coming out of there, over to the air intake.
    Groovy Forums :: Topic: 2010 Toyota Prius (1/1)
    So it's maybe under this bump:
    View is looking from passenger side front bumper. The large hole is oil filler.
    Since the only other reason to take off that cover would be for valve adjustment, and the 3rd gen has hydraulic (automatic) adjustment, I'd be inclined to leave it be.
  3. ChapmanF
    19,038
    On a 3rd gen, I don't think it lives in the valve cover. It seems to screw into the "NO. 1 VENTILATION CASE" which is mounted facing forward on the cylinder head, maybe just above the no. 4 port of the intake manifold, if I've got my bearings right (nope, it's facing forward on the block, so it's beneath the intake manifold and harder to see) in this illustration.
    The hump on top of the valve cover is for a hose to the filtered air intake.
    -Chap
  4. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    It's directly under the intake manifold. You can get it from underneath the car but along with pulling the under panel, it takes a stubby 22mm wrench and patience to turn the thing a fraction of a turn at a time. I can't imagine pulling it from above without pulling the I.M. but that's not saying it's impossible.
    If you've got high mileage on your 2010, you may want to do an EGR port cleaning on the I.M. and do the PCV while you've got it off.
    #4 m.wynn, Jun 15, 2015
  5. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    Is this what you want?
  6. bisco
    52,863
    i thought these cars were supposed to be maintenance free.
    m.wynn likes this.
  7. ChapmanF
    19,038
    Ah, I can see the advantage in signing up on techinfo to view the manuals directly, since turning this one into PDF just turned all the hyperlinks into little dead blue boxes that say "INFO". (Most of them probably aren't needed, but the one with the formula for correcting a torque wrench extended with a wrench could be handy for people.)
    The older manuals were just electronic versions of paper ones anyway, so nothing was lost converting them to PDF ... but no more, alas, no more....
    -Chap
  8. Mendel Leisk
    42,355
    I cleaned the throttle body yesterday, and it was kinda hard to see, but looked like an oil sheen beyond the flap, coating bottom of throttle body. Would that be where that PCV valve inlets? Thinking so.
    If you follow nutzaboutbolts throttle body clean video, gives a good idea. Also pull out the box below engine filter and you're there.
  9. Mendel Leisk
    42,355
    NO. 2 CYLINDER HEAD COVER, conjures up a lot of images, none remotely like this, lol:
  10. frodoz737
    4,807
    2,561
    33
    That's like saying marriage is supposed to be maintenance free. Some are better than others...but you pay as you go or you pay in the end. ;)
  11. bisco
    52,863
    at least the pcv is easy to find in my marriage.:cool:
