PCV Value Replacement ( Autozone vs Toyota Dealer part)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wirelessjava, Jul 9, 2016.
  1. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
    It is 65K miles on my Prius 2005 so I am going to change my PCV Valve
    Autozone Price - 4.99
    Toyota Dealership Price 15.81
    Is the dealer ripping me off or do Autozone parts comparable ? Any suggestions?
  2. JC91006
    16,939
    8,647
    Why do you feel the need for a pcv valve at 65k? Are you the original owner? Such low mileage is amazing
    johnnyb588 likes this.
  3. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    The dealer is not ripping you off. You're going to pay around $15 anywhere. I replaced mine a couple months ago (at 150k) and I think I paid $14 for the part (OEM).
    1. I would not replace your PCV. You have low miles. Unless it's giving you issues, just leave it be.
    2. If you are intent on replacing it, I would not go with an AutoZone part where such a small savings incentive is at stake. I'd fork over the extra $10 for OEM.
    3. Again, I wouldn't do it, but if you do, clean the throttle body and MAF while you're at it, and you might want to check your plugs as well. All of that stuff is easy to do together and generally occurs at similar intervals.
    wirelessjava likes this.
    52,917
    i would go oem, but that's the way i roll.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I asked the dealer to change plugs @ ~110,000miles, and they suggested PCV replacement for which they charged me $11 since they were doing the plugs anyway, so basically it was just price of part and free installation. - FWIW - Wil
    wirelessjava and bisco like this.
  6. Patrick Wong
    18,214
    6,531
    At 65K miles you do not need to be concerned about replacing the PCV valve. When you get to 100K miles, then start thinking about that.
    You are located in CA and the dealers there typically have parts prices higher than MSRP. I personally would call pricing above MSRP to be a rip off...
    For example, the AutoNation Toyota Gulf Freeway parts website shows MSRP at $9.88 while their price is $7.72.
    EMISSION SYSTEM for 2004 Toyota Prius
    Parts.com offers the same part for $6.83. That probably will be shipped by a Toyota dealer in NV.
    Parts.com® | Genuine-Factory-OEM-2004-Toyota-Prius-Base-L4-1.5-Liter-ELECTRIC/GAS-EMISSION-SYSTEM
    Obviously you have to pay for shipping, so it makes sense to buy parts over the web when you have several parts to buy at once: air/oil filters, wiper blades, etc.
  7. wirelessjava
    wirelessjava Member
    105
    23
    Union City, CA
    Thanks for the help Bros
  8. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    FYI, after reading Patrick's comment, I rechecked my purchase. I paid about $7, so I was wrong on the price I listed earlier.
    "Rip off" is relative, but I would still suggest you try to find this part elsewhere where you can get <$10 including shipping online. $5 isn't much, but it's still $5 you don't HAVE to spend if you don't want to.
    Also, my initial suggestion still stands. Don't replace it yet. :)
  9. Mendel Leisk
    42,383
    Especially for something so one-in-a-long-time, no point to gamble over a few $. An aftermarket part might be one-size-fits-several, might be a poor fit, or the more insidiously, the spec's might be different, the internal spring strength for example: might open sooner or later.
    Or not. But again, I'd fall back to my first sentence.
  10. gatorglenn
    gatorglenn Member
    138
    45
    Atlanta
    I think many aftermarket parts are as good as Toyota factory parts. But for a few dollars difference I would probably get the factory one. It is not a part tat needs to be replaced very often.
    My question is, where is the PCV valve located? I would like to change mine.
    Glenn
  11. Patrick Wong
    18,214
    6,531
    You need to remove the wiring harness over the engine valve cover for access. The PCV valve is sticking out of the valve cover, pointing towards the inverter.
  12. gatorglenn
    gatorglenn Member
    138
    45
    Atlanta
    Thanks. I will look.
    Glenn
