PCV Valve Replacement Questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Aug 6, 2016.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Some of the items @farmecologist references I have done as well (including the BGProducts EPR treatment). But this has also been in the last month or so and is too early to tell or report on. Will keep the thread referenced updated with my findings as well.
    So 2 data points coming soon;).
  2. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    True in theory, but has there ever been a clear case of replacing the PCV valve actually curing excessive oil consumption in a 3rd-generation Prius? Usually, I gather, that's more a case of grasping at straws.
    Mendel Leisk and Raytheeagle like this.
  3. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Or maybe asked in a different way:
    How many PCV valves have been found to not be functioning or checking?
    My bet on this is low and then you have to look elsewhere. I know in my case the PCV valve was still checking at 120 k when I first began to notice oil consumption. And replacing it did not solve the small drink of oil:(.
    Continued diligence with oil level monitoring on the dipstick and adding as needed while troubleshooting the other causes of oil consumption will help keep the problem from getting worse.
  4. Mendel Leisk
    42,254
    I'll confess to not even having a full grasp of how the pcv valve works. Let me take a stab, just from what I've read in the last few days, without peeking:
    The PCV (Positive Crankcase Ventelation) valve connects high up on the crankcase wall. A hose runs from it's other end to the intake manifold. When there's high vacuum in the intake manifold, it's sufficient to pull a spring-backed ball bearing off it's seat, and allow air to flow from the crankcase to the intake manifold.
    This action creates a partial vacuum in the crankcase. To counter this, another hose runs from the valve cover, to the air intake snorkel, somewhere between the throttle body and the air filter.
    In the old days, crankcases just vented to the atmosphere, but that was causing pollution, so the PCV valve was introduced, basically to run the crankcase air back into the combustion chamber. But now, if the PCV valve is stuck in the shut position, the crankcase can't vent, which it needs to do, what with all the piston motion.
    From here on I'm completely out of my depth, but thinking: bad things start to happen, with a poorly vented or completely sealed crankcase, specifically oil getting up past the piston rings, or perhaps getting into the intake via that second hose??
    This seems to cover it:
    #24 Mendel Leisk, Sep 16, 2016
    dorunron likes this.
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Finally did it, and what a pain! A long-handle, fine-tooth ratchet helps a lot. I had a short handle, fine-tooth socket. I couldn't get the torque wrench on at all. A colling hose kept popping the socket off. For the simplicity of the task, it was a real PITA. My knuckles did a lot better than I thought they would. With the socket continually popping off, it can be a real knuckle-scraper.
    Of course once I got the valve off, it was still working. But it didn't jiggle as noisily as the new valve, so maybe replacement was a good idea. I hope.
    Raytheeagle likes this.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Definitely buried in there. Easiest to do when the intake manifold is off. I did mine off cycle but will do it again when the intake manifold is off at 200 k miles.
    You end up getting more people for the end of March meet up?
  7. Rebound
    3,996
    2,645
    Portland, OR
    At one point I was ready to give up and pull the intake, but it's not THAT hard, it's just a pain for what it is. The Great Big Jack helped a lot. I'd hate to do it with no headroom.
    Nobody's signed up to come out end of March except you. And you better show :)
    Maybe we'll get signups as we get closer.
    #27 Rebound, Feb 26, 2017
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I think I talked @mmmodem into coming. You mind if I ask someone else who might be interested?
    I got it on the calendar, so I should be good(y).
  9. Rebound
    3,996
    2,645
    Portland, OR
    Yeah, well if you're counting on my circle of friends we'll get nowhere. As I said, I think four cars, two at a time will work. ,
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I'll see what I can do(y).
  11. ChapmanF
    18,954
    It's easy to get that description sort of backwards-ish, because it's not exactly intuitive.
    The condition where manifold vacuum is highest is idle (well, deceleration can be even higher), when the engine is sucking against a closed throttle plate. So you have a very high manifold vacuum, but the engine is not producing much blow-by gas (and anyway, allowing much extra airflow into the manifold would mess up the idle).
    The condition with the most blow-by gas is full-power operation, which is also when the throttle is way open and the manifold vacuum is relatively low.
    So the PCV valve is an odd critter that allows more flow when the vacuum pulling on it is lower. The pintle on the inside moves to restrict flow as the manifold vacuum increases. (It can also close if manifold pressure goes positive, to prevent backfire from reaching the crankcase.)
    There's a "University of Toyota" class on its theory of operation; the course material is on techinfo.
    -Chap
    Mr. F, CR94 and Mendel Leisk like this.
  12. Mendel Leisk
    42,254
    Yeah I recall now: high vacuum at idle, and it drops as you accelerate.
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Threej and Mendel Leisk like this.
  14. Rebound
    3,996
    2,645
    Portland, OR
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The "catch can" settles out the oil in the blow-by and traps it so that it doesn't reach the throttle body and intake manifold. I've used one in the past and it works. All I did was buy the water separator, remove the foam filter, add hose nipple to inlet and outlet, cut the PCV hose and attach. This was on a '95 Saturn SL2 with lots of blow-by. I ended up emptying it every couple of weeks.
    Threej likes this.
  16. Rebound
    3,996
    2,645
    Portland, OR
    Oil isn't a problem with the Prius PCV, and its location would make such a catch can installation impossible.
  17. ChapmanF
    18,954
    The weird labyrinthine wart on the engine block that the Gen 3 PCV valve is screwed into is an oil separator.
    -Chap
    mjoo, kc410 and Raytheeagle like this.
  18. Rebound
    3,996
    2,645
    Portland, OR
    I guess that's why oil isn't a problem with the Prius PCV...
  19. Mendel Leisk
    42,254
    For the Toyota spec'd PCV valve thread sealant "adhesive 1324, three bond 1324", it looks like Loctite 271 is equivalent. See attachment:
  20. Mendel Leisk
    42,254
    For a counterpoint, looked up a Honda instruction. Basically: take off old one, put in new one, no mention of tricky coatings. I think I like that.
    There is a washer though.
