PCV Valve weird noise !
Discussion in 'Gen 2 Prius Main Forum' started by jack sparrow 111, Jul 10, 2020.
  1. jack sparrow 111
    jack sparrow 111 Junior Member
    50
    los angeles
    hello guys,
    my mechanic has cleaned the throttle body on my Prius 2006 and has also replaced the PCV Valve and after driving it for two minutes, i started noticing this weird sound inside my hood...it happens when i hit the brake and i am almost coming to a full stop, i thought first it was the fan but it felt like the engine was revving , my mechanic said it is normal, the valve is adjusting itself and you should drive it for a while and it will be gone ...after i left my mechanic i drove for about 80 miles and the noise is still there ! what do you suggest ? take it back to have it looked at , maybe the Pcv valve itself is defected ? .. i have no idea...
  2. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Take it back!!!
    jack sparrow 111 likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Any dash lights displayed:whistle:?
    I'd check the area around the PCV for damage as sometimes when the valve gets replaced, the cover gets cracked:cool:.
    Wouldn't be the first time that has happened ;).
    But a trip back to the mechanic would allow for a better diagnosis:).
    Good luck and keep us posted(y).
    audiodave likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    So...the throttle body butterfly is positioned by a small electric motor and it's position is measured by a sensor. The motor positions the throttle body based on the ecu signal and feedback from the position sensor. At idle, the ecu is looking for an rpm. This is one of those things that is a 'learned' position. As the throttle body gets dirty, etc, the position it returns to for idle will gradually change. If the throttle body gets cleaned, and the butterfly goes to its current learned position in the ecu memory, it may be open further than needed and rpm will be higher. Over several cycles, the ecu will 'learn' updated positions and will start positioning the throttle body correctly.
    After doing a TB/MAF sensor cleaning, disconnecting the 12v battery for a moment will reset the ecu's to their default values and the 'learned' values are no longer used. It should now match more closely to what the car needs.
    This is also why people run into trouble sometimes after disconnecting the 12v battery. All the ecus go to default values, including all the 'learned' values. If your throttle body is dirty, but now the ecu has returned to default, it may not be in a good position for starting the car and codes out.
    SFO, ydpplqbd, dolj and 1 other person like this.
  5. jack sparrow 111
    50
    los angeles
    Hello ;-)
    There are no dash lights displayed...i will keep you updated about this
    Thank you so much
    Raytheeagle likes this.
  6. jack sparrow 111
    50
    los angeles
    Hello,
    Thank you so much for your input... my mechanic said something similar what you have mentioned..
    "Over several cycles, the ecu will 'learn' updated positions and will start positioning the throttle body correctly "
    since this is most likely the fix for my issue, then i should just keep driving it until it fixes itself ? no need for another diagnosis ? right ?
    i am just hoping that the PCV Valve is not defected...
  7. jack sparrow 111
    50
    los angeles
    oh ok..thank you.. i was little hesitant because my mechanic is about 1 hour and 15 minutes away from me... i gotta go back i guess
  8. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    No, you don't have to take it back. Just disconnect the 12 V battery for 15 secs, if it is not behaving. Refer to
    TMR-JWAP's post #4, which corroborates what your mechanic said:
    and is right on the money, although, I don't know why your mechanic did not just disconnect the 12 V and save you all the angst.
  9. jack sparrow 111
    50
    los angeles
    Thank you so much for your input ;-)
  10. jack sparrow 111
    50
    los angeles
    Hi Guys!
    I want to let you know that the problem has been fixed by itself...as i went back to my mechanic for another diagnosis, 10 minutes before i got there, the idling noise was gone.. I went test driving my prius for 30 minutes around the area of my mechanic and the noise did not come back
    At this point, so far so good.. I guess that the ECU was getting adjusted to the new PCV valve and the throttle being cleaned.
    I thank everyone on this thread for their time and help.
  11. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    so whats next step if TB buzzing sound does not go away... its been 2 months... lots of miles. 2004 184k. never buzzed before. did chg inv coolant pump after cleaning.
  12. ChapmanF
    19,019
    The buzzing sound is different from the position-learning issue described in this thread.
    The buzzing sound is nothing but an inherent result of the way rapid pulses are used to position the throttle.
    Mine makes the buzzing sound and always has. You'll be able to hear the buzzing sound in any Prius if you open the hood and listen for it.
    I might not have any satisfying answer for why you had never noticed the buzzing sound from yours before. There could be various reasons why it could be slightly louder from one throttle body and slightly softer from another. There could be various reasons why its loudness could change slightly over time or with wear. There could be differences if you did work on the car that changed the tension or position of some of the rubber hoses, leaving them better conductors of sound.
    But the bottom line is it's a sound that isn't going to go away. If you're sure it was once quieter, you could try drastic things like replacing the throttle body, and the new one might buzz more quietly. But then again, it might not.
  13. 2004priusgal
    76
    new jersey
    Upgrade
    fyi, buzzing sound has quieted, still there but not as loud.
    unfortunately, i now have hv battery issue... always something....
    thank you for wise words.
