Pcv valve? Where are you?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Its MEEEEEE!!!!, Jul 16, 2013.
  1. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    As needed?
    m.wynn likes this.
  2. Avi's Advanced Automotive
    776
    363
    "Putting a device in to cool the [extremely hot] EGR [gasses before putting them into a plastic intake manifold] seems [not] odd."
    Raytheeagle likes this.
  3. JC91006
    16,935
    8,646
    Well I had the part and the darn thing was taken apart. So I replaced it....or I could've returned the part for a few bucks
  4. dame3780
    dame3780 Member
    61
    55
    SoCal
    Anyone know the part number for the PCV valve? Is it also called the pressure valve? Trying to buy part and want to confirm. Thanks in advance!
  5. JC91006
    16,935
    8,646
    Serious? After reading this thread?
    m.wynn likes this.
  6. dame3780
    dame3780 Member
    61
    55
    SoCal
    Seriously...yes. No need to be a dick. I have a part # from an online store that is different and want to confirm. They are calling it a pressure valve.
  7. JC91006
    16,935
    8,646
    I just don't think you need it
    Toyota Genuine Factory Part
    Part Number: 1220437010
    PCV VALVE Prius
    Fits 2011 Toyota Prius Base
  8. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Decided to dive into EGR/cooler today...found some interesting blockage
  9. Tbkilb01
    218
    187
    Louisiana
    IMG_5576.JPG IMG_5567.JPG IMG_5559.JPG IMG_5552.JPG Carbon
    Everywhere
    Probably sticking valve
    Need JIS screwdriver to remove... really locktighted on...worked it loose from other end though...
    #49 Tbkilb01, Aug 3, 2017
    Mendel Leisk and Raytheeagle like this.
  10. Tbkilb01
    218
    187
    Louisiana
    IMG_5579.JPG IMG_5581.JPG Cleaned up
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    :eek:.
    How many miles when you undertook this? Any symptoms that caused the cleaning, or was reading about it sparking some interest? How long did it take? What cleaning method and solvents were employed?
    Looks like doing the job was a good idea though(y).
  12. Tbkilb01
    218
    187
    Louisiana
    IMG_5583.JPG IMG_5584.JPG Cold start up rattle
    Cleaned oil puddle a while back but still heard rattle this morning after 4hr hour drive yesterday. She's at 185500. Been wanting to do it for months but always something else to drink I mean do!
    Really a very easy job. Considering.
    3 cans CRC cleaner. Took my time
    Cleaning but no longer than anything else... best to do plugs valve body pcv oil puddle oil catch can etc all together because wipers come off and air box and snorkel too...but then again after 2-3 times wipers come off and on in 10-15 minutes...
    To do job need a hose crimping tool or vice grip wrapped around towel to no damage hose...
  13. Mendel Leisk
    42,293
    Or corks? Too messy?
  14. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Depends on what you got "just Layin' around";).
    Most suggest hose clamps. I prefer to pool the job with inverter coolant change. Makes much less mess or the potential for it(y).
  15. Tbkilb01
    218
    187
    Louisiana
    Once hose pinched off
    Just coolant in egr cooler drains maybe a cup? Not messy at all
    Tight quarters is all
  16. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Clean your pcv and put an oil catch can in. Your car will run smoother, get better mpg and won't knock at start. Your throttle body will be cleaner because the catch removes the oil before entering the intake plenum under the throttle body. There is an oil catch can thread.
    Puddle is not normal. That oil will coat the intake plenum, intake valves, pistons, exhaust valves, heads, egr cooler and egr valve with carbon that will decrease performance, mpg, reliability, etc. That knocking at start up is from too much compression, from oil, coolant, water condensation and fuel. The knocking is bad for the motor. Head gasket failure is what you asking for. That 3 layer steel head gasket start to wear out causing the engine to eat coolant and then you have a bent rod, thrown rod(breaks block) or hydrolocked engine. The usb toyota has for a new manifold did nothing to fix these problems. The oil catch can will.
    mjoo likes this.
  17. dame3780
    dame3780 Member
    61
    55
    SoCal
    Not sure how a question about a part number illicits your opinion and snide remark.
    I'm just going to change it out bc it's cheap and an easy swap anyway. I will be completing this, plugs, and egr at 120k in a few weeks.
    The part number was good so thanks.
  18. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO:
    dame3780 likes this.
  19. Tbkilb01
    218
    187
    Louisiana
    IMG_5532.PNG Think Toyota tired of swapping head gaskets plenums injectors yet?
    I've got that can on my next to do list...out of EGR Valve into can with Brillo material then back to intake? ... seems easy enuff. Sounds like something I saw on my 54 chevy back in the day
    #59 Tbkilb01, Aug 4, 2017
