PCV valve
Discussion in 'Gen 3 Prius Technical Discussion' started by Jason Beauchamp, Oct 21, 2020.
  1. Jason Beauchamp
    Jason Beauchamp New Member
    25
    Lancaster, KY
    I’ve got a 2012 with 87K on it and I don’t see any evidence of using oil yet so my question is should I still replace the PCV when I install the OCC or wait till it actually starts using oil?
  2. ASRDogman
    ASRDogman Senior Member
    6,056
    3,251
    It's an $8-10 part, and pretty easy to change, if you're going to have the intake manifold off.
    But if you can get to easily, wouldn't hurt to change it with a new Toyota one.
    For some reason, cleaning it doesn't seem to do much. For any car.
    So for peace of mind, and possibly to eliminate a problem down the road, change it.
    Jason Beauchamp likes this.
  3. Jason Beauchamp
    25
    Lancaster, KY
    Good point thanks. I guess since I’ll already be right there might as well go ahead and replace it.
    ASRDogman likes this.
  4. Mendel Leisk
    38,644
    I've shot carb cleaner through ours twice now (and reused); seems fine. Only 88k kms though. But who knows, maybe the internal spring weakens over time? And yeah, the replacement part's around $10. Don't cheap out; get genuine Toyota part, say from dealership parts department.
    New ones come with thread sealer applied. When I reinstalled ours I applied a little loctite blue with oil resistance (not the "permanent" red stuff). You don't absolutely have to I think, it just keeps from having an oil bloom where it screws in.
    Paul E. Highway likes this.
  5. 310 Prius Owner
    310 Prius Owner Junior Member
    17
    IL
    I agree. I would replace if you are able to get to it. No sense waiting until it starts using oil to replace it.
