PDA (Proactive Driving Assist) may be better than I thought
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Jun 21, 2024.
  1. Will B
    Will B Active Member
    454
    419
    Denver
    2023 Prius Prime
    XSE Premium
    More out of curiosity, I enabled this feature early on (it was default off). Ever since doing so, it seemed to only do very little things that seemed weird, but not really anything major. It might apply brakes a few seconds before me following a slowing car, or maybe on a curve slow down by 1-2MPH is all. I filed it away as mostly a gimmick that wasn't that useful, but not annoying either, so have left it on.
    That changed on a drive a few weeks ago. It was on a nice twisty mountain road I drive frequently where as mentioned above, PDA usually did only very minor slowdowns on some curves. I normally drive right at the speed limit. The only major exception is if doing so is backing up traffic--especially on a 2-lane highway. That happened to be the case on this road that time, so instead of the posted 50MPH I was going 60. With that as my cruise speed, now PDA was pretty active and made major corrections. 60MPH on the straight parts, but still all the way down to a bit below 50 on the tighter curves. It was kinda of fun to watch it work!
    So, sounds like for PDA, it is mainly useful if you are a speeder! :) I can see that the posted limit is really for taking the curves safely, so PDA just ends up taking you down to the speed the road designers came up with if you are going faster.
    will
  2. Hammersmith
    Hammersmith Senior Member
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I've also got it enabled and haven't minded it so much. The roads around here are mostly flat and straight, but there's one stretch that I drive occasionally that has two tight turns at the county line(the larger county roads were offset by 3/4 mile, so there's a correction at the line). The correction was built when average speeds were closer to 50-55mph, but the typical speed on the road is now 60-65. The PDA lets me just leave the cruise control alone as I approach the curves.
    Reading your post, I've also realized it's going to be nice to have the next time I go over the Rockies. The last few times I did it, I was in my old 2010 Prius. There were always a few times going downhill that I would be more focused on the road and traffic than the speedometer. I'd be coming downhill and approaching a turn and look down and realize I was going 90+mph. Once or twice I looked down and was in triple digits. It will be nice having a smarter cruise control helping out when I'm getting task saturated.
    GcinFl likes this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't know if mine has changed, but the last time I checked, it follows curves until it decides not to. It can be a bit unnerving, when you're going around a curve and it suddenly disengages. Of course I know that I'm supposed to be ready to take over control all the time, but if it lets go in a curve at the wrong second, there's a chance of hitting oncoming traffic.
  4. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    My son uses the Blue Cruise on his new truck and he said he can drive for hours on the freeway without ever touching the steering wheel. But he has navigation and I think it uses the built in maps in addition to the cameras.
    I tried it on our road trip and didn't like it at all. It tried to veer to right when driving by off ramps. IMO, if you're driving 80 mph on the freeway, you should be in control at all times.
  5. AndersOne
    AndersOne Active Member
    346
    200
    Europe
    2023 Prius Prime
    But arent you talking about normal DRCC with LTA? I activated in my options that Speed should be decreased during DRCC in curves but thats kinda unrelated to PDA. PDA seems more relevant when DRCC is not active.
    I had moments too though where it tries to catapult me out of orbit, despite decreasing speed.
  6. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    PDA is actually deactivated when DRCC is active. So you get less steering assist. But the DRCC has its own curve monitoring function for speed.
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Who knows what all those acronyms mean?
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I just got back from a 2000 km trip, and the various driving assistants are a godsend. I'm not nearly so tired after a day of driving. One potential hazard is falling asleep at the wheel. It's supposed to detect closed eyes, but that has never worked properly.
