PDF file of the official CHP report on the Sikes affair
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by justlurkin, Mar 17, 2010.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    While there's a possibility the car was in a malfunction state and very difficult to duplicate, it's confirmed you needed to press the brake pedal at least 50% in order to kill the throttle. One can in theory apply an indefinite times of braking without triggering a single log of the throttle being killed as long as you stay under 50%.
    Only Toyota knows what these log data really mean. The rest of us can only speculate based on limited information offered us.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I can't say for the 2010, but with my Gen II Prius, the ABS system does not "hammer" the brakes. The ABS system on my 2006 is virtually undetectable without the indicator light.
    Tom
  3. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Yes, I noticed that the Prius has LINEAR manifold brake pressure porting for each wheel along with pressure sensors for each wheel but didn't realize they were also used for ABS.
    I would vote that they restore the "hammering" effect so the driver gets a better "headsup" about ABS activation. Or at least "vibrate" the brake pedal.
  4. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    "..at least 50%...
    The factory documentation seems to indicate that when the brake light switch is triggered the system goes into braking mode, regen if possible/needed. That would mean a very light touch on the brakes would disable the forward "DRIVE" system.
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    No, that's a different issue. We're talking about brake override (as in killing the throttle), not just any braking. It won't disable the forward drive system if the throttle/accelerator is engaged when it's less than 50%. In fact, it forms the basis of Sikes allegedly "wearing out" the brakes while maintaining a constant high speed.
  6. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Sorry, I just can't buy into this 50% issue.
    The factory documentation is very clear on this point, the brake light switch will ALWAYS result in the HSD drive train going into "simulated" neutral (the ICE RPM may or may not decay), or into regen mode if regen is needed and/or is possible.
    And for just what logical reason would anyone specify such a design aspect...??
  7. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    the phone call was 24 minutes
    lets say he was pressing the brakes on and off for 20 minutes for a total of 254 times
    thats 4.7 times a minute at roughly 12.7 seconds of braking.
    would somebody do that in a panic situation?
    i think not
  8. qbee42
    18,058
    3,079
    Northern Michigan
    This disagrees with the tested results. Hobbit reports measuring brake activation while applying full throttle. He also reports that the override is triggered by the pressure sensors on the hydraulic system, not the brake light switch, and kicks in somewhere near 50%.
    This is also what I have experienced with my Gen II, although I lack the extra sensor wiring that hobbit has on his Prius.
    Tom
  9. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Except we don't know exactly what the time course of the 250 data points is. This question has been brought up and nobody knows except Toyota.
  10. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I-8 and La Posta is about halfway between San Diego metro and Jacumba. If he was headed back from SD which seems likely, he had probably gone some 40 miles before the 911 call.
  11. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    First they told use that both the brake pedal and gas pedal had been "cycled" ~250 times. Then they came back with a correction that said only the brake was cycled 254 times and the throttle remained fully open the entire time.
    "Throttle" remained fully open the entire time....!!!
    If there is anyone out there in internet land that would not have pumped the brakes numerous times in the feverant hope "the next time will work" then that person is an idiot of the 1st magnitude.
    250 times I will willingly attribute to a computer flaw, maybe like the one Dr. Gilbert uncovered until proven otherwise.
  12. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Is this a serious question? Because 500 horsepower was being added to the car that had to be overcome by the brakes. It doesn't matter if the power is applied at the front or the rear wheels. Of course the front brakes have to overcome the engine driving force (at a ratio of 70 to 80%).
  13. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    And that makes good logical sense to someone...??
  14. vegasjetskier
    269
    29
    Then you don't understand the purpose of ABS or how it works.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You are purely guessing and you would not make that mistake, if you understand how HSD works.
    ICE is 76 hp and the generator (MG1) is less than 30 hp. If the HSD is "stuck" in accelerate, MG1 will be burned out. It was not and the car continues to drive normally.
  16. qbee42
    18,058
    3,079
    Northern Michigan
    It makes sense to me. Some people two-foot the pedals, or do heel-toe driving. I don't, and it seems a bit silly with a car like the Prius, but Toyota is trying to prevent one problem without creating more.
    The only time you need brake override is when you are braking hard. In an emergency, you hit the brakes hard. If you are playing with them, then you must not need very much braking. This is why Toyota uses a 50% threshold.
    Tom
  17. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Assuming the HSD control computer was stuck in the "set/accel" mode what makes you think that the ICE, MG1 and MG2 would not be properly coordinated, just as the would be in the "normal" set/accel mode.
  18. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    I'll say it again....
    3 people like this.
  19. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Dr. Gilbert was already proven otherwise, lol.
  20. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    Looked at CNN report on the Harrison case today. Toyota recorded the accelerator pedal was press 100%. But in Sike case. No mention on the position of the accelerator was given. Do Toyota show only what they want us to see (the truth but not the whole truth, may be 50%, 60%??).
