Peace Out Infernal Retainer Clip
Discussion in 'Gen 4 Prius Main Forum' started by davecook89t, Nov 9, 2023.
  1. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    All that, only to find out my battery fan filter is perfectly clean after 6 years of owning the car. Oh well, better safe than sorry. IMG_20231106_125729579_HDR.jpg
    bisco and Mendel Leisk like this.
  2. Mendel Leisk
    42,358
    Did you figure out anything in the process, make it easier next time? Or it’s just your typical “diabolical fastener”…
  3. davecook89t
    1,093
    832
    I was turning the Phillips head screw counterclockwise while simultaneously prying the washer up with a flat head screwdriver, but it wasn't budging. Then I tried the brute force method with a couple of different pairs of pliers, but it wasn't easy to get a good grip, as can be seen by the damage I did to the hole in the panel. Diabolical is a good description. I guess I will try to pick up another clip from the dealer, but I'm tempted to just leave it unclipped. The panel stays in place quite well anyway.
  4. davecook89t
    1,093
    832
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    Very simply, I would have drilled a small hole with a reverse counterclockwise drill bet and released it with one of these fluted screw extractors.
    5Pcs Screw Extractor, Straight Fluted Screw Extractor Set, Broken Damaged Bolt Easy Out Removal Tool Square Type
  6. davecook89t
    1,093
    832
    I'll keep that in mind for future issues, but for a plastic screw it seems like overkill. The screw was turning, but possibly the ribs on the underside of the washer had become too brittle to bend inward. In fact, it was quite a job to pull and twist on the head of the washer until it separated from the bottom part, which (I guess) fell into the crevice next to the battery.
  7. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Sure glad I read in the Owner’s Manual how to do it before I tried it the first time.
  8. Mendel Leisk
    42,358
    Seriously, there was something in there??
  9. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Yep! Even had pictures (that’s how come I could figure it out ;))
