Peanut butter interior smell. Where is it coming from???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Big Thirsty, Sep 20, 2021.
  1. Big Thirsty
    Big Thirsty New Member
    Boston, MA
    Alright guys. Here’s one for you. I’ve got a 2011 Prius 3 with a bad interior smell and I can’t figure out where it’s coming from. First, it smelled “earthy” and now it smells like peanut butter. You can’t smell anything outside when the doors are closed. When I open any of the doors, the smell hits me like a wall.
    First, I pulled everything out of the hatch to see if there was evidence that I was leaking water under and pooling under the spare tire. Nothing.
    I brought it to the dealership. They pulled down the headliner and checked some interior panels. Nothing. They gave it a hose down to see if there was leaking and if all of the drains were clear of debris and working. Nothing.
    Then, I brought it to get detailed. Full interior wipe, vacuum, and shampoo. Then an ionizer for a few hours. Nothing. If anything, it smelled a little worse.
    I read about how the problem could be a dirty A/C condenser so I bought the kit and the dealer performed the A/C refresh. Nothing.
    I’m at the end of my rope, guys. I’ve spent over $400 and the car still smells like peanut butter and I don’t know how to fix it or even where to look next. Any suggestions?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Did you check the air cabin filter
  3. Big Thirsty
    Boston, MA
    Yes. The dealer replaced it last week.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,129
    6,982
    Texas Hill Country
    Ionizer or ozone generator? Ozone usually does the job. I would hope they checked the cabin filter when they did the evaporator cleanup.
  5. Big Thirsty
    Boston, MA
    Yep. The ionizer was in the car for a few hours after they detailed it, so I'm told. But I don't know if they used an ozone generator. I'll research about the difference between that and an ionizer.
    Also, they replaced the cabin air filter a week ago.
  6. bisco
    52,883
    i wonder if a mouse dragged in some bait
  7. JC91006
    16,938
    8,647
    Was this car ever in a flood?
  8. bisco
    52,883
    of peanut butter?
  9. Big Thirsty
    Boston, MA
    No. For the first 36,000 miles, it was in Arizona. Now it has 42,000 miles and lives in Boston, but it has never been flooded.
  10. JC91006
    16,938
    8,647
    The interior bits are not very hard to strip out. Remove everything including the hatch area, seats, and carpet. Do a thorough cleaning and then let the car bake in the sun for a few hours. Open the doors and take a deep breath, see if you get a whiff of fresh air afterwards
  11. Big Thirsty
    Boston, MA
    Yeah. The car smells like peanut butter now. It's smelled bad for a couple of months. At first, it smelled differently, sort of earthy. I can't put my finger on what it smelled like before. The smell has changed and for the past month or so, it smells like peanut butter. I can't figure it out.
    I feel pretty confident about removing the seats, but I'll have to watch a video about removing the carpet. I'll try that this weekend.
    #11 Big Thirsty, Sep 20, 2021
  12. tankyuong
    1,555
    662
    Central MO
    Maybe the mechanic was eating peanut butter and had it all over his hands when he installed your cabin filter
    Henrik Helmers and bisco like this.
  13. burrito
    burrito Active Member
    274
    114
    Sounds like mold.
    Take the car to one of those places that specializes in mold removal in homes, and ask them to check out your car. If they confidently say, "Yeah, this car smells like mold," then you can at least be pretty sure you know what the problem is. If so, they may be able to help you tackle it.
  14. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Have you considered asking Lil’ Thirsty?
    Serious question: Have you had COVID? I’m a breakthrough case and my smell o’ meter is completely out of wack even months later.
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I removed the carpet. You don’t need to remove the carpet to solve this problem. No way. The seats? Definitely. Very easy. Pull the 12V battery ground first, then move the seat back, remove the two front bolts, move it forward, remove the two rear bolts. Then you rock the seat backwards, and remove the two or three electrical connections. Each is unique and they are keyed, so you cannot accidentally reconnect them wrong.
    With all three seats out… try the smell test again. Now you know if the problem is in the seats or in the carpet. If it’s the rear bench, you can scrub that thing down with a garden hose. The front seats have air bags so you can’t be quite as aggressive, but you can use a lot of soap and water on them.
    If the interior still smells after you remove the seats and you shampoo the carpet, you need to pull panels. First take out the spare tire and all the stuff around it, then the plastic pieces near the rear battery. Animals can enter and nest near the 12V battery, so that’s the first place I’d look if the smell is in the back. If it’s in the front, pull the cabin filter and reach into the fan, which is like a basket, and see if anything’s fallen into it. You have to do this by feel. That would be the first place where something can enter.
    Most plastic molding inside a Prius is easy to remove with a trim tool, but start with pulling the seats, see if the smell follow the seats or not, then if needed, shampoo the carpet. You can solve this.
    When I pulled my entire carpet out, I filmed it, but I haven’t edited it yet. So if you need more help, let us know.
    #15 Rebound, Sep 21, 2021
