Peeling film or whatever it is(tint??)— see picture
Discussion in 'Gen 4 Prius Main Forum' started by Valoree, Jun 16, 2019.
Tags:
  1. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    These people are stealers, not dealers as is clear by the costs stated. Any competent person can pop these off and the replacements come with the attachment pins, even though you will not need them if you are careful removing the originals.
  2. William Redoubt
    1,228
    1,172
    There is something very Canadian about that, "ahem" (paraphrasing the only scene I have ever seen of Bill and Ted's Excellent Adventure).
    Mendel Leisk and Valoree like this.
  3. Valoree
    Valoree New Member
    24
    Arizona
    Probably will do that.
  4. Valoree
    Valoree New Member
    24
    Arizona
    Well was going to shell out the $85 off this other website, someone mentioned, for the parts and then see if I can get a someone to install them, but maybe I can just go to a body shop and see if they can fix it without shelling out a lot of money for that parts. I don’t get taken Advantage often, but I know nothing about these plastic panel things and I don’t know what’s normal on price/labor for parts like these-that’s why I ask.
  5. Valoree
    Valoree New Member
    24
    Arizona
    Not often, but I have,maybe that and the Arizona heat when not in a garage.
    what do you mean wrap them?
  6. Valoree
    Valoree New Member
    24
    Arizona
    Makes it look so simple, but again I’d have to use the sun as “heat lamp” and knowing my luck I would break something.
  7. Mendel Leisk
    41,406
    I think getting it off the double-sided adhesive is the first step; it won't move at all until that's accomplished. Maybe slip something like a putty knife in to keep it from rebonding.
    Valoree likes this.
  8. Valoree
    Valoree New Member
    24
    Arizona
    I wish there was a you tube video then I’d feel a bit better about removing it myself, going to check with auto body shop around me and see if they can repair it for cheaper than purchasing the side panels..or may just deal with it for awhile.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    GOOGLE something like Car Body Wrap.
    It's a vinyl coat - it's actually removeable apparently, so your grey car can be pink for the next 2 years, then matte (yuk) blue for a few more, then have stripes - and finally metallic gold.
    But I'd be surprised if they couldn't put a wrap over those 2 panels - pick your colour!!!!
  10. Valoree
    Valoree New Member
    24
    Arizona
    Well that’s cool...So do you think a car wrap place might actually wrap those 2 panels? Or I’d have to wrap it myself? Might forgo the stripes and pink for now though:)
  11. alanclarkeau
    7,045
    7,592
    Ring a couple of them up - or drive there and show them - it's not a "normal" thing - but it should be an easy job for them. I saw a YouTube of a car being done once. Can't see the one I was thinking of - but this gives an idea - just a roof, mirrors on this one.
    I've seen some in metallic etc - the only one I know of personally had a clear coat put on - I think on his bonnet (hood), front panels and sills.
    RojaRosie likes this.
  12. krmcg
    2,592
    2,392
    Whittier, CA
    Vinyl wrap film needs to have a good surface to look its best. Underlying "textures issues" will show through the thin film. But I agree that it will be easy to pull them off and replace them with the relatively inexpensive replacement parts.
    Valoree likes this.
  13. alanclarkeau
    7,045
    7,592
    Yes, I have no idea - it might be a very cheap job - but might surprise me with being exorbitant.
  14. William Redoubt
    1,228
    1,172
    Vinyl wrap. Just on a small part. See this Amazon Ad.
  15. alanclarkeau
    7,045
    7,592
  16. Valoree
    Valoree New Member
    24
    Arizona
    I called a wrap place and they said they don’t do anything if clear coat is peeling, so may just buy parts.
    krmcg likes this.
  17. Mendel Leisk
    41,406
    Maybe some brave soul with a fourth gen can try prying it off on theirs, see how easy it is?
    Valoree likes this.
  18. Valoree
    Valoree New Member
    24
    Arizona
    And video it:)... I actually Might try when I get the parts, it seems easy enough-I don’t think the parts come with adhesion tape stuff-so not sure how I would “glue” it back and all that. I talked to another body shop and they said $55-$60 labor for each side- a little cheaper than Toyota dealer, but not by much.
  19. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    IF......you "order" these parts, will they come in the right color......or will they have to be painted ??
  20. Valoree
    Valoree New Member
    24
    Arizona
    Well I think on all prius’ this panel is black... I will call Toyota in am to double check.
