Pending PA80 code
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Dec 15, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    I bought a refurbished pack back in February and up until now its been performing incredibly
    A solid 49 to 50 mpg avg
    This week my mpg dropped to 40 and just now saw the charge level spike from near near zero to full green.
    Scanned it and have a pending PA80 code
    This pack should be in warranty, I got it from 2nd life batteries.
    However if its not... who is a good option for NEW modules?
    #1 Banksy, Dec 15, 2020
    52,877
  3. Banksy
    415
    133
    That's the guy
    He does the newer style modules, correct?
    52,877
    i think so, you can check out his website 'newpriusbatteries'
  5. Prodigyplace
    12,718
    11,850
    Central Virginia
    New OEM modules are only available from a Toyota dealer. If you must have OEM modules a pack from a low mileage wrecked Prius is your only other reasonable choice.
    @2k1Toaster has a kit of new cylindrical cells that basically gives you a new pack for $1600 delivered. You can sell any if your old modules to lower the cost further.
  6. Banksy
    415
    133
    How much would the whole set of used modules be worth?
    I've been in communication with the owner of the company and he wants me to run some tests.
    I ran techstream and didn't see any pending codes on there like I did on my autel
    Here is the data I pulled
    First two are with car at idle
    2nd two are with the car in accessory mode
  7. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Which 2nd life Biz? The one in Oregon or the one in New York?
  8. Banksy
    415
    133
    Oregon
  9. PriusCamper
    13,468
    5,438
    That's a good sign. Catch him at the right time on the phone and you may have a friendship out of it, as in he's honest and generous.
    Also always has the best modules / packs in my experience. Scholarly type, always investing in upgrading his equipment too... Just got another $20K rig for transition to Lithium. Fascinating what he does way out in the middle of nowhere
    My strategy has been to bring him a junkyard pack I buy every once in a while and get modules and sometimes chassis. Always the best module in every pack are his spare modules.
  10. Banksy
    415
    133
    So he's gonna take care of this right? He sounds like he just wants me to stress test it and go from there.
    Should I run live data for the modules in techstream and drive it around? What's the best way to do that?
  11. PriusCamper
    13,468
    5,438
    Not sure what his protocol is but if he's asking you to test stuff that seems like a good sign.
    The more you can DIY this the better and seeing as you know your way around techstream swapping your own battery pack isn't that much more diffcult.
  12. Banksy
    415
    133
    Why won't tech stream let me look at data with the car running?
    I'm trying to see the voltage levels of this battery under load but it keeps saying it lost communication with the vehicle whenever I start the car.
  13. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    I'd suspect the OBDII cable. Is it a cheap MVCI? If yes, try another cable. You might need to get 3 or 4 before you get one that is reliable. If that doesn't appeal, try the VxDiag cable.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    A better cable SHOULD be more reliable, however I use a genuine Mongoose Pro Toyota cable and still have loss of comm here and there.
    Before you get too far, make sure your 12V battery is good. If it is weak then you can have a glitch when you try to Ready up.
    Another option might be to get the Dr Prius app with one of the reccomended OBD2 dongles (go to the Dr Prius site). Then you can log the pertinent data from the HV battry ecu.
