Pep Boys 12v Battery Woes
Discussion in 'Prius c Technical Discussion' started by kayadash, Sep 4, 2018.
  1. kayadash
    kayadash Junior Member
    New York
    2013 Toyota Prius C Four. Pep Boys lists this battery as fitting: Bosch 51-440BAGM.
    Bizarrely, the clerk informed me the battery wouldn't "fit" and went on to describe the posts before I cut them off and told them to just put the old one back in the car. I was told "older" Prius models have an issue with this and was told only Toyota has the battery.
    How is my Prius C different from any other in terms of the battery terminals or the compartment? I've never read anything about specific variances in Prius C models regarding this. I did my research here regarding the part as well.
    This sounds like inexperienced clerks. Has anyone had similar experiences trying to get a non-OEM battery for the Prius C?
    Also, does anyone know the OEM part number for the 12v battery?
  2. kayadash
    New York
    FWIW, my system has a smart key.
    52,848
    while he had the old one out of the car, you should have asked him to show you the difference.
  4. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Looks like Prius c uses the smaller Prius battery for non-SKS Gen 2. In a Gen 2 you could buy the larger battery and just replace the battery tray with one from an SKS Prius. Looking at the other Prius c threads, looks like you have to bend the hold-down strap and leave a part off--no wonder they said "No".
    The Pep Boys site says it fits, but the Bosch batteries site can't find anything. I think Toyota is the only source for the small batteries.
    bisco and MelonPrius like this.
  5. kayadash
    New York
    I have the smart key system, it's a Four trim.
    ITBland likes this.
  6. ITBland
    433
    278
    Parts lookup shows only one battery for Prius c (S34B20R), Gen 2 lookup shows 2 (w/ & w/o SKS). Not absolute proof, but McGeorge Toyota parts is usually a reliable source.
  7. Runswithdog
    Runswithdog Junior Member
    30
    I replaced my 12 volt battery today for my 2013. Currently all the auto part dealers don't list a battery for our Prius C on their program. After reading several threads on this website, I went with the Bosch AGM 51-440BAGM battery available from Pepboys. I took my old one in and compared. They have they same height and width, but the Bosch is longer, which the Prius C has extra room and even the battery bracket fit back on. The Bosch battery also has the vent tube. I just had to switch the plug and tube sides on the battery and connect it to the tube from the Prius. The only thing that would not fit was the protective plastic cover that was over the original battery.
    It was funny my six year old battery was cleaner than the new one.
    I have attached pictures of the original and new battery as a size comparison and how the Bosch battery fit in my Prius C. IMG_2676.jpg IMG_2677.jpg
  8. bisco
    52,848
    is it sks?
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Yup, the smaller battery is the non-sks S34B20R battery and the larger one is the S46B24R sks model. Although that is true for the Gen 2 Prius, I wonder which one is OEM for the C? Nice that it has room for the larger one though.
