Permanent Air Filters - in home
Discussion in 'Fred's House of Pancakes' started by h2photo, Jul 26, 2008.
  1. h2photo
    h2photo Member
    432
    Chandler, AZ
    Just wondering if anyone uses these are what they see are the pros/cons of them. It seems silly to buy the disposable ones when there are ones you can take out, rinse, & put back in!
    If you do have any recommendations, which brands?
    TIA!
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I use an electronic air cleaner in both homes. In essence, an electrostatic precipitator. A bit of a PITA to wash the cells, but excellent filtering. If you allow the cells to get dirty, efficiency drops off. Poorly designed ones also tend to put ozone into the home
    I cut out large furnace high-eff filters to use in the intake of my heat recovery ventilator. That way, all the fresh air sucked into my house is filtered first. Makes a huge difference in indoor air quality
    The cheap washable filters are no better than cheap furnace filters, with the advantage you wash them out instead of tossing them
  3. h2photo
    h2photo Member
    432
    Chandler, AZ
    Thanks Jay, that seems to be a bit over my head lol so I guess we'll just stick with what we've got for now!:rolleyes:
