Persistent P0401- dealership says replace intake manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusNovice911, Nov 21, 2019.
  1. anonymous
    anonymous Member
    177
    99
    US
    Did they clean the EGR sub-manifold inside the intake manifold or only the intake manifold airways?
    BTW how is P0401 detected anyway?? We had "insufficient flow" and pre-ignition for a long time but the light only came on at 200k miles when the cooler was absolutely plugged! I found one way that defeats P0401 is if the EGR valve is left open to air; maybe the EGR valve detects the upstream pressure difference over the downstream vacuum?
  2. ArmyChief
    ArmyChief Junior Member
    71
    50
    North Port, FL
    Did this ever get fixed or did you sell?
