Pesky problem with transmission "P" lock, red triangle, or parking pawl.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew_Ph, Dec 19, 2017.
  1. John McG.
    John McG. Junior Member
    55
    25
    The service manual has a test for the actuator and Luscious Garage has a video, showing a way to make sure if its having a problem. Its all electronic/magnetic with now contact parts in the actuator itself. It looks like there is an orbital gear ring that is greased. If it turns easily, its likely ok. Mine was acting up and turned out to be a P-CON connection issue due to corrosion in the harness or the HV battery was tripping the code. . I traced it out using the suggested protocol in the service docs. I noticed that the P-LOCK error didn't clear when I disconnected the aux battery, but certainly did when I disconnect the harness from the trans EMU and the HV EMU. In any case I think mine is fixed.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    Here's to hoping it is just the connection.
    Replacing the prawl can be a challenge.
  3. Andrew_Ph
    Andrew_Ph Junior Member
    46
    MI,USA
    Where are these service manuals? Or could you photocopy the relevant pages?
    On another note, I found a handy dandy battery voltage chart online and for an AGM battery it says mine, usually at about 12.5v, for instance right now at 12.43v, is at about 75% charge. I dont know whether this effects the signal from the actuator right when the ignition is turned on or not. It should be 12.8 to 13v for full charge.
  4. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    You can get access to service manuals via Toyota for a daily charge. Or buy hard copy on eBay.
  5. Andrew_Ph
    46
    MI,USA
    what is an EMU?
  6. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Engine Management Unit.
  7. Andrew_Ph
    46
    MI,USA
    On a side note, I mentioned the valve for the evaporative system purge, seems now I dont see any problems with it, I dont know if it a weather change or me messing with the battery. Now on Torque it shows a small positive pressure sometimes and -3000 pascals vacuum when normally driving, seems like a lot more then i saw before.
  8. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    its either low battery voltage or its bad wiring to the left side of the p con fuse under the hood, you need to jump the blue wire number 4 from the left to the left side of the p con fuse, simple, you tube it, you will see
    if you drive in salt then that car is going to have tons of under the hood fuse issues and will even take down the main power to the power train control module in pass glove box and prevent trans from working at all, been there, done that, salt roads and a prius under hood fuse box
  9. Andrew_Ph
    46
    MI,USA
    blue wire from left side of what? Where do you get the number 4 from?
  10. ChapmanF
    18,222
    or another possibility as covered in the workup procedure in the repair manual. John McG.'s procedure in #21 is best, just do the diagnosis and find out what's causing the trouble in your car. Following "it's always X" posts on PriusChat or youtube can work sometimes, but can also lead to mistakes you'd avoid by diagnosing the car that's in front of you.
  11. Michael Cyr
    Michael Cyr Junior Member
    Belgrade, ME
