PeterJMC's Build Thread
Discussion in 'Gen 3 Prius Accessories and Modifications' started by peterjmc, Jun 12, 2013.
  1. peterjmc
    917
    188
    Clarksburg, MD
    On 3 June 2013, I traded in my 2010 Prius Five for a 2013 Prius Five w/Advanced Technology Package.
    Over the 2.5 years I had my 2010, I did a good bit of modding. It took me about 7 hours to pull all the mods off and, for the most part, return it back to stock. Most of those mods should be finding their way back onto the 2013.
    Here is the story of my 2013 Prius :)
    Before (Stock):
    After (Progress Pics):
    As of 7/18/2013
    As of 6/17/2013
    My old 2010:
    '10 Prius Five: Racecar Edition Traded In
    F8L and 2clicker like this.
  2. peterjmc
    917
    188
    Clarksburg, MD
    Modification List...
    12/30/2013 - See Post #33
    Tints installed, 3M Crystalline 70 (full front windshield) and 3M Crystalline 40 (all other windows) - TintFX
    12/03/2013 - See Post #33
    Directed/Viper Smart Start installed. DIY! - amazon.com
    8/28/2013 - See Post #34
    Cusco Strut Tower Bar - Fredbeansparts.com
    Cusco Front Power Brace - Fredbeansparts.com
    Cusco Center Power Brace - Fredbeansparts.com
    Hotchkis Rear Sway Bar - Fredbeansparts.com
    07/18/2013 - See Post #24
    3M Black Matte Vinyl Applied to Hood - qedinc.net
    Painted Upper and Lower grill inserts w/Flat Black Plasti-Dip
    Wrapped the DRL/Turn signal lamp in Lamin-X (Clear) - autowindow.com
    Wrapped the foglight housings in Lamin-X (Yellow) - laminx.com
    Disabled the low speed noise device
    Painted engine cover w/Flat Black Plasti-Dip
    07/14/2013 - See Post #21
    DIY phone mount (replaces shift knob) - amazon.com
    Carmate storage tray insert (painted flat black) - eBay.com
    Tap turn signal module (LED light compatible) - autowindow.com
    06/23/2013 - See Post #19
    3M Matte Black Vinyl Wrap applied to hood - qedinc.net
    JDM Engine Covers - eBay.com
    06/17/2013 - See Post #8
    Footwell and Glovebox Lexus OEM LEDs - Fredbeansparts.com
    Interior 5,000k exLED LED Light kit - exLEDusa.com
    Wheels: Forgestar F14 - mooreperformanceparts.com
    Size: 18x8.5, +48 offset
    Weight: 18.8lbs
    Color: Textured Gunmetal
    Tires: Continental DWS, 225/40/18 - iagperformance.com
    To Be Installed:
    Front turn signal, wigwag setup
    Hatch overhead LED lights
    Hella Supertones
    Illuminated door scuff plates
    Lower door moldings
    Mouse proofing!!!!!!
    JDM window visors
    Pedal set w/dead pedal
    Prius plus body kit
    Rear wiper delete
    Replace dash LED dash lights and button back lighting with red LEDs
    Side mirror reverse tilt module
    Sound dampener (B-Quiet and Dynamat)
    Steering wheel
    Turn signal mirrors w/blue mirror lens
    Valenti taillights
    Vinyl wrap
    Yakima roof rack.
  3. 2clicker
    2clicker Member
    114
    28
    St. Louis
    off to a great start already. ill be watching this thread.
    peterjmc likes this.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You forgot the most important mod:
    Mouse-proofing the Prius!
  5. Chris S
    Chris S Active Member
    323
    109
    Gilbert, AZ
    Me too. Sounds like a good list and a lot of fun.
  6. peterjmc
    917
    188
    Clarksburg, MD
    Thanks guys! Most of the parts were installed on the old car. It was fun putting them on, then pulling them off. It's gonna be fun to put them back on to enjoy them again :)
    I'm hoping to report on being able to get some of the easy stuff put back in the car tomorrow.
    I dropped off a number of parts to the powder coater on Monday. It will be about six weeks until I get them back. The Cusco underbraces had a a few rust spots and paint chips from their life under the car. They are all going to be cleaned and coated in Astatic Red. I'm toying with the idea of throwing my Eibachs in there too... :)
    I wanted to go orange but Toyota uses orange as an identifier for "High voltage" components. I didn't want to confuse the mechanics if I needed work done on the car.
    Parts getting coated:
    - Hella Horn cages
    - Cusco Front Lower Arm Brace
    - Cusco Front Brace
    - Cusco Mid Brace
    - Cusco STB end brackets
    - Hotchkis Front and Rear sway bars
    2clicker likes this.
  7. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)I really like the Prius 5, especially with ATP. Once I decided on a Prius, I had to have the 5 with ATP. I was swayed at the last minute and went with the Prius Plug In Advance. Put the Prius 5, 17" wheels on the first week. Takes a sharp eye to notice the difference between the two.
  8. peterjmc
    917
    188
    Clarksburg, MD
    6/17/2013 update @ 1,200 miles
    I was able to get a few things done today.
    1) Installed my Pure White (5,000k) exLED interior LED light kit.
    2) Replaced the Toyota OE LED glovebox and footwell lights with Lexus OE LEDs
    3) Replaced the Toyota cabin filter with a Fram Fresh Breeze filter
    4) Picked up my wheels and freshly mounted tires from IAG Performance
    1) Pure White (5,000k) exLED interior LED light kit.
    The exLED light kit which I purchased for my 2010 Prius five went in perfectly in my 2013 Prius five. Looks like Toyota revised the light housing for the vanity mirror lights between 2010 and 2013. You are able to access the bulbs a lot easier. The only LED lights from the kit which I did not use are the license plate LEDs. I separate housings for those :)
    The 5,000k color matches well with the Lexus OE LEDs but the intensity of the brightness is MUCH stronger. The brightness of the front and rear dome lights are adjustable on the LED circuit board itself.
    2) Lexus OE LEDs - Part No. 81080-22040
    I replaced the yellow/orange LEDs which illuminate the drivers and passenger side footwells and the glovebox. The Lexus part 81080-22040 is a direct fit replacement. You will need three of them. All three are easily accessible and very simple to just pull out of their housings, and push them back in.
    These lights match well with the Pure White (5,000k) exLED interior light kit but are MUCH less intense in brightness. This is fine for me since I don't need flashlights on my feet while driving :)
    3) Fram Fresh Breeze Cabin Air Filter - Part No. CF10285
    I pulled out the OE one and slid in this. It's an air filter with some carbon filtration.
    4) Forgestar F14 wheels and Continental DWS 225/40/18
    Wheels and tires are now on the car! I previously had Continental DWS 215/40/18s mounted on these and had them replaced with 225/40/18s. The 215/40/18 was too much stretch for my liking. I might have to go back because the 225s look like they might have fender rub issue
    My car is in need of being lowered now! :)
    Wheels: Forgestar F14 (Forgestar Wheels Custom Rotary Forged Flow Formed Concave Performance Wheels)
    Weight: 18.8 lbs
    I need to thank More Performance for being a vendor for ordering these wheels. They provided excellent customer service throughout the order process and even seven months down the road when I thought I had issues.
    Moore Performance (Moore Performance & Race Parts)
    I also need to thank IAG Performance for mounting and balancing the wheels and tires. They also provided excellent customer service and took care of me, my car, and my parts wonderfully. The staff were very informative and made sure that they addressed all of my concerns.
    IAG Performance (IAG Performance - Subaru Performance Parts & Service. IAG Home - www.iagperformance.com)
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Congrats on ur new Prii. Gonna love the transformation.
  10. JuRuKi
    JuRuKi Junior Member
    61
    where did you order those LEDs?
    Your old car looks nice btw! :)
  11. vietalogy
    vietalogy Junior Member
    23
    Grand Rapids, MI
    I would also like to know where you got them too?
    Sent via Galaxy S4
  12. peterjmc
    917
    188
    Clarksburg, MD
    Thanks!!
    Hello,
    - I purchased the interior 5,000k LED kit from exLEDusa.com
    exLED Toyota Prius (for sunroof model) ('10~) (Map, Dome, Vanity, Trunk, Door, License Plate) custom interior light kit
    - I purchased the Lexus OEM (illuminates white) LEDs from Ryan @ Fredbeansparts.com
    See the 6/17 posting for the part number for the Lexus OEM LEDs.
  13. peterjmc
    917
    188
    Clarksburg, MD
    I'm teetering on the idea of going coilovers or staying with Eibachs.
    Someone please build my confidence and say their coilover setup is smoother/more comfortable than springs!
  14. Chris S
    323
    109
    Gilbert, AZ
    I discussed this awhile ago with a buddy who has coilovers in his Talon and he showed me how riduculously easy they were to adjust. The car does ride nice set for street (?) He also explained that if you ride a lot of miles, coilovers cannot have parts replaced, it's all or none. I'm not so sure how true this is but I bought it and went with the Eibachs knowing that every year or so I'll just replace the struts/shocks as they wear and refresh the ride, still only $400 per year or two, versus $2k for good coilovers. In reading over PC the last year, and in my past week's adventures, it does sound like coilovers are the way to go if you want to spend the cash. Just my 2 cents :)
  15. peterjmc
    917
    188
    Clarksburg, MD
    Coilovers can be rebuilt and parts replaced once they start to wear. That could depend on what the brand purchased though. TEIN USA | SERVICE | Overhaul Basic Price
    I'm eyeing the Tein Street Advance... or maybe just the Basis :)
  16. Chris S
    323
    109
    Gilbert, AZ
    Wow. That's not bad at all!
  17. David2sav
    David2sav david2sav
    107
    171
    San Jose, California
    Nice color choice (y)
  18. peterjmc
    917
    188
    Clarksburg, MD
    Today, I used my ATEQ Quickset tool to swap TPMS sensors registered to the ECU.
    ATEQ finally updated their vehicle database to include the 2013 Prius :)
    Using this is so easy!
  19. peterjmc
    917
    188
    Clarksburg, MD
    6/24/2013 Update @ 2,500 miles
    I was only able to get a few things done on Sunday out of the many things I wanted to do. I'll post pictures if anyone really wants to see some.
    1) Installed 3M matte black vinyl wrap on the hood
    2) Installed JDM engine covers
    Installed 3M matte black vinyl wrap on the hood.
    Wrapping my hood wasn't too much trouble from what I expected it to be for one person. I might redo the hood because I'm anal like that and like everything perfect. The way I laid down the vinyl, I had to make a number of small pull and stretches in one area. The number of small corrections I had to make made the vinyl appear off color in a small area. After finishing the hood, I perfected the technique and am pretty sure I can get the whole thing on by myself and it turn out great.
    While cleaning the hood and claybaring it before applying the vinyl, I noticed two small nicks from what I can only assume to be from road debris :( . I'm hoping that this vinyl can do as good as a job as my clear bra on my previous car, the vinyl is thin in comparison.
    I have to thank my uncle at Quality Engraving & Design Inc. (http://qedinc.net) for being my source for my vinyl :)
    I purchased these off a seller on eBay who packaged all three of the pieces together. I had these on my 2010 and just put them back on the new car. They fit without issues. I'm thinking about taking the cover for the inverter and using it as a repository for stickers.
    I'm hoping to get the front bumper and headlights covered in the next week.
    Thanks for stopping by!
    Burna J and David2sav like this.
  20. patdeezy
    patdeezy Junior Member
    23
    awesome stuff so far!
