Petrol Engine not Running
Discussion in 'Gen 2 Prius Main Forum' started by john crompton, Dec 7, 2020.
  1. john crompton
    john crompton New Member
    23
    Wales
    Hello all, I'm new here! I've looked all over this site and can't find anyone with exactly my problem. My 2005 Prius has the red triangle of death, plus a christmas tree of others! I've replaced the 12v battery with a Toyota genuine and checked all the cells in the HV battery, replacing two that were a bit low (but not by much). I've checked the oil level and the AM2 fuse. I split all the wiring connectors I could find, cleaned and reconnected them, plus took out the ECU next to the HV and made sure all the pins on that were good. The car will now start after batteries reconnected (petrol engine) but only runs for maybe 20 seconds before shutting off and throwing up all the warning lights again. I bought a code reader and the codes are both hybrid system related. What else can I check?
  2. john crompton
    23
    Wales
    PS - car will move under battery power...
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    How many miles on this 2005?
    Which OBD2 code (DTC) reader are you currently using?
    Could you please post the OBD2 codes (DTCs) as well.
    For code readers, many prefer a 'mini-vci' cable and techstream (dealership technician software) installed on a windows device.
    Best not to use the 'electric' only feature, as over time it only taxes the HV battery more. Also the HV battery is what 'starts' the engine.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Spill the beans...what were the codes? I'm sure someone can get you going in the right direction if we know where you're starting from.
    strawbrad likes this.
  5. strawbrad
    953
    1,007
    It's really likely that the gas engine is not running for 20 seconds but is just being spun by the electric motors.
    Is the ready light coming on?
    It would help if you share the codes you have read.
    The first thing to check when an engine will not start is the MAF sensor. A spec of dust on the hot wires deep inside the MAF will disable the engine.
    jerrymildred likes this.
  6. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Now you have me thinking. I'd bet one of the codes is a P0A0F engine fails to start and/or a 3190 poor power, especially if it actually tried to keep running for 20 seconds.
    I went through this with a 2005 recently, where the car coded out after being at a red light. Car had been driven for about 30 minutes prior to the red light.
    Engine would turn over, trying to start, and would run like crap for a few seconds before dying out. Pretty sure it ended up being the throttle body. Looked inside and it was all crudded up. Poked it/rotated the butterfly with a screwdriver in case it was stuck and the car fired right up. Got the car to the guys house late that night. Next morning, when we tried to start it, same thing. poked TB again and it fired up again. Scrubbed the TB really good with a toothbrush and some TB cleaner and it hasn't coded since. Been a few weeks now.
  7. john crompton
    23
    Wales
    Wow - woke up this morning to some superb responses! Thanks people. I'll get out there when I've got my act together and get answers to your questions ASAP. I have to say that the throttle body and MAF sensor comments look promising... especially as I have changed the air filter a week or so before this problem occured... (I would have included this fact in my initial question if I thought it might have been even remotely relevant!) The car has about 160,000 miles on it and was dealer serviced up until last year. The current situation has forced me to try and "save money" (ha ha) by doing the work myself.
  8. john crompton
    23
    Wales
    OK, the codes were P0A80 and P3000, which made me think it was something wrong with the HV side. I've had an HV battery fail before and the symptoms this time are completely different, so I was never really confident that messing with the traction battery would do any good, but heh...
    No the engine definately starts and starts to charge the HV, then the revs rise and it cuts out with all the bells and whistles that go off when it is feeling poorly. ;-) Dust on the MAF is my next challenge - thanks for that clue!
    Sorry, but I'm using the cheapest reader I could find... it plugs into the port under the dash and bluetooths to the phone. Codes were P3000 and P0A80. Just under 160,000 miles.
    Sorry! P3000 and P0A80...
    I've just realised why responses are so delayed... the Atlantic Ocean! It's like trying to have a real-time conversation with someone on Mars! :) Anyway, it is around freezing here today and fluctuating between rain and snow, so, as the car is outside, it might be a while before I get back to you all with my findings... Water in everything most certainly will NOT improve the situation.
    #8 john crompton, Dec 8, 2020
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    P0A80...uh-oh..lost that bet...………..
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    yeah at work have to correspond with German Engineers there's about a 30 min lag time for them to get an email from Florida and vice versa.
    That's alot of switches there.
  11. john crompton
    23
    Wales
    Before I turn in, what do we think about grease on the M5 connector...?
  12. strawbrad
    953
    1,007
    Maybe but not necessarily.
    Running out of gas will result in the P0A80 code.
    A failed battery with a P0A80 will not keep the gas engine from running.
    #12 strawbrad, Dec 8, 2020
    SFO likes this.
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    There is a five (5) post threshold, and now you're unmoderated for better or worse, sink or swim.
    john crompton likes this.
  14. john crompton
    23
    Wales
    Fuel issues...? Hmmmm... I mentioned this comment to my wife who was driving at the time of the initial failure (why is it ALWAYS the wife driving???) and she said, "Oh, I had just had the low fuel warning, so I put a couple of gallons in..." We live 1/2 a mile from the filling station, that sounds about how far it would take for bad fuel to get to the engine... doesn't it...? Surely not that simple? If so, what do I do?
  15. strawbrad
    953
    1,007
    Again, clean the MAF. Make sure the two wires deep inside are clear. Next I would try running the engine with a little starting fluid.
    My point is anything that keeps the engine from running can run the battery down.
  16. john crompton
    23
    Wales
    Yes, that's what I'm most worried about - once I've cranked it too many times and drained the traction battery I'm done for... :-(
  17. john crompton
    23
    Wales
    Ok, I've tried various things in between the rain - M5 plug (that was a pig!), MAF sensor (no joy, although it was covered in black dust), fuel pump check (all fine). After further interrogation of the wife, she mentioned a bad eggs smell... could this have been a battery cell giving up? When I stripped and re-built the battery I only did what I did last time and checked for cells down on VOLTS. I swapped out two which were at 6.5 ish, when all the others were between 6.9 and 7.1... Could it be that I have a cell with volts but no amps? I have seen this with rechargable AA batteries... How to I find the cell to change if this is the case, I've only got a multimeter? This is doing my head in - and to top it off, both my other cars are failing too... 1972 Volvo 145 and a 1968 Hillman Husky. AAAARRRGGGGHHHH...
  18. strawbrad
    953
    1,007
  19. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Does the local petrol station also sell diesel fuel?
  20. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    It could be that your battery is pretty much at the depleted stage. If those are the actual module voltages, you may already be in trouble.
