Phantom phone calls on start-up
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Jan 4, 2015.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    About 50% of the time when I start the car, the message center tells me that I'm calling my own cell. Then I need to press the "source" button, and the button for whatever I was last listening to, to get it to disconnect. Anyone else experience this, and if so, any idea why it happens? It seems completely sporatic.
    52,889
    whatever happen with the fuel filler problem?(n)
  3. mikenancy1
    105
    Geneva, IL
    Regarding the fuel filler issue, the first response I received seemed to have the answer, and succeeding answers confirms that we are not alone. In any case, we've followed this advice, and the issue has nor recurred:
    Many have this experience. It has to do with the bladder in the fuel tank becoming stiff and unwilling to expand in the cold weather. The main things to do are to open the gas cap for a couple of minutes before starting to fill, allowing the bladder to relax, and to fill as slowly as possible. Some pumps go faster than others, so one can't use them full blast.
    Read more: Fuel filler problem | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    52,889
    thanks!(y) i don't have a phone, sorry.:)
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    Ummm... the Gen III Prius (2010+, including the plug-in) doesn't have a fuel bladder.
    rxlawdude likes this.
  6. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Poster in that specific thread was referring to the fueling issues of their daughter's 2005 Prius, which does have a fuel bladder.
  7. bisco
    52,889
    sorry to confuse!:p
  8. alekska
    alekska Active Member
    435
    138
    Atl
    The only thing I can think of is 12-V battery voltage drops too much during the start-up drain, which causes sporadic behavior. This would be suspect if you dont drive much, and 12-v battery does not have enough time to charge while in "Ready" between startups. Try to use a small battery charger to bring your battery to fully charged condition, and see if mystery calls disappear.
    - Alex
  9. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    What kind of phone and is it plugged in/charging when this happens?
  10. markabele
    5,084
    1,782
    Nebraska
    Was it on an iPhone? If so, what model?
  11. mikenancy1
    105
    Geneva, IL
    Correct! This problems was on my 05 Prius.
  12. mikenancy1
    105
    Geneva, IL
    Yes, it's a 4S.
  13. mikenancy1
    105
    Geneva, IL
    It's an iPhone 4S, and it is not plugged in or charging.
  14. markabele
    5,084
    1,782
    Nebraska
    I've experienced the phantom call on my girlfriend's iPhone 4s. Has never happened on my android and hasn't happened yet since she got the 6.
  15. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Unrelated to phantom calls, but definitely an Entune thing: Have any of you with Android 4.4 phones noticed that message alert (when a new SMS comes in) no longer works? It worked great with my existing phone till a few weeks ago. Now, if a new message comes in, it does not transfer via BT to Entune. (The message list includes only what was received when the BT connection was made.)
